Find out the speed of an object
  • Thread starter Thread starter wapleman
    Speed
To determine the speed of a 10.0 kg box acted on by a constant force of 50.0 N, the relevant equations of motion under constant acceleration must be applied. The initial speed is 2.0 m/s, and the distance traveled to the second timer is 150 cm. The acceleration can be calculated using Newton's second law, F = ma, which allows for the determination of the acceleration needed for the motion equations. The SUVAT equations can then be used to find the final speed as the box passes the second timer. Understanding these principles is crucial for solving the problem effectively.
wapleman
A 10.0 kg box is acted on by a constant force of 50.0 N. If it passes a first timer with a speed of 2.0 m/s and then travels 150 cm to a second timer, what would its speed be as it passes the second timer?
I know usually to find out the speed of an object it is usually distance over time.
I know the distance being 150 cm
However as there is no time I've come to a complete stand still
Stuck at the beginning, if someone would be kind enough to point me in the right direction please.
What equations do you know related to motion under constant acceleration?
Vf = Vi + at
If that helps at all.
I have the distance, just not the acceleration to use that equation
wapleman said:
Vf = Vi + at
You should be familiar with the SUVAT equations if you are expected to solve a problem like this.
See e.g. https://en.m.wikipedia.org/wiki/Equations_of_motion#Uniform_acceleration.
As for the acceleration, you are given enough information to find it. Which of Newton's laws relates force to acceleration.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
