MHB Find Parabola Given Focus & Directrix - Help Needed
  • Thread starter Thread starter MarkFL
    Focus Parabola
To derive the equation of a parabola with a focus at (-5, -5) and a directrix of y = 7, the relationship between the focus and directrix is used. The equation is established using the distance formula, leading to the quadratic function y = -\frac{x^2 + 10x + 1}{24}. The vertex of the parabola is located at (-5, 1), with the directed distance from the vertex to the focus being -6. Consequently, the final equation of the parabola is (x + 5)^2 = -24(y - 1). This provides a complete representation of the parabola based on the given parameters.
MarkFL
MHB
Here is the question:
Find the formula of this parabola?
Derive the equation of the parabola with a focus at (-5, -5) and a directrix of y = 7.
So... I've tried this one over and over but can't seem to get the right answer. Help anyone?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Abs,
A parabola is defined as the locus of all points $(x,y)$ equidistant from a point (the focus) and a line (the directrix). Using the square of the distance formula, we may write:
$$(x+5)^2+(y+5)^2=(y-7)^2$$
$$x^2+10x+25+y^2+10y+25=y^2-14y+49$$
Combining like terms, we obtain:
$$x^2+10x+1+24y=0$$
Solving for $y$, we get the quadratic function:
$$y=-\frac{x^2+10x+1}{24}$$
Hello, Abs!
Find the equation of the parabola with focus at (-5, -5)
and directrix y = 7.
Code:
                    |7
              :V    |
              o     |
       *      o     |*
              :F    |
The focus (F) is (-5,-5).
The vertex (V) is (-5,1).
The form of this parabola is: (x-h)^2 \:=\:4p(y-k)
where (h,k) is the vertex,
and p is the directed distance from V to F.
We have: (h,k) = (-5,1) and p = -6.
The equation is: .(x+5)^2 \:=\:-24(y-1)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
