Find Parts for OrCAD Capture | Simple Diagrams
  • Thread starter Thread starter Gerardo Ortega
    parts
Finding basic parts like switches and light bulbs in OrCAD Capture can be challenging due to its steep learning curve. Users need to add symbol libraries from the specified directory to access various components. The ANL_MISC library contains some of the needed components, but the search for common parts may still be difficult. It is suggested that users continue exploring available libraries for better results. Overall, utilizing OrCAD for circuit simulation with PSpice requires persistence and familiarity with the software's library system.
Gerardo Ortega
Hi All,
I am trying to make a simple diagram that uses some basic parts like switches, light bulbs, fuse holders, but I am having a difficulty finding these parts in OrCad Capture. Not sure if those parts are part of their libraries, or I need another program from that. The reason I am using Orcad, is because I want to use Pspice to simulate and calculate volatges through the circuit.. Any idea?
thanks in Advanced!
I had the same problem when I started using Orcad. It is a difficult tool to figure out on your own.
In your capture schematic you have to add a symbol library from C:\Cadence\SPB_16.6\tools\capture\library. There is a list of *.olb's (symbol libraries) there. Once you insert this into your design then you can try to place a part, select the library and then you will see a list of parts in the library along with the symbols. Hope this helps.
Likes berkeman
thanks,
I was able to add the libraries, I also found in ANL_MISC library some of the components that I need..
It has a very steep learning curve.. But looking for a common part should not be so difficult, Unless I am using the
wrong software for it. I will keep looking
If one has more ideas, will be great thanks
Gerardo Ortega said:
thanks,
You can find libraries this way:
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
