MHB Find Polynomials Fulfilling Real Coefficient Equation
  • Thread starter Thread starter anemone
    Polynomials
anemone
MHB
POTW Director
Let $k\ne 0$ be an integer. Find all polynomials $P(x)$ with real coefficients such that $(x^3-kx^2+1)P(x+1)+(x^3+kx^2+1)P(x-1)=2(x^3-kx+1)P(x)$ for all real number $x$.
Mathematics news on Phys.org
Let $P(x)=a_nx^n+\cdots+a_0x^0$ with $a_n\ne 0$. Comparing the coefficients of $x^{n+1}$ on both sides gives $a_n(n-2m)(n-1)=0$ so $n=1$ or $n=2m$.
If $n=1$, one easily verifies that $P(x)=x$ is a solution, while $P(x)=1$ is not. Since the given condition is linear in $P$, this means that the linear solutions are precisely $P(x)=tx$ for $t\in \mathbb{R} $.
Now assume that $n=2m$. The polynomial $xP(x+1)-(x+1)P(x)=(n-1)a_nx^n+\cdots$ has degree $n$, and therefore it has at least one (possibly complex) root $r$. If $r\notin {0,\,-1)}$, define $k=\dfrac{P(r)}{r}=\dfrac{P(r+1)}{r+1}$. If $r=0$, let $k=P(1)$. If $r=-1$, let $k=-P(-1)$. We now consider the polynomial $S(x)=P(x)-kx$. It also satisfies the given equation because $P(x)$ and $kx$ satisfy it. Additionally, it has the useful property that $r$ and $r+1$ are roots.
Let $A(x)=x^3-mx^2+1$ and $B(x)=x^3+mx^2+1$. Plugging in $x=s$ into the given equation implies that
a. If $s-1$ and $s$ are roots of $S$ and $s$ is not a root of $A$, then $s+1$ is a root of $S$.
b. If $s$ and $s+1$ are roots of $S$ and $s$ is not a root of $B$, then $s-1$ is a root of $S$.
Let $a\ge 0$ and $b\ge 0$ be such that $r-a,\,r-a+1,\cdots,r,\,r+1,\cdots,\,r+b-1,\,r+b$ are roots of $S$, while $r-a-1$ and $r+b+1$ are not. The two statements above imply that $r-a$ is a root of $B$ and $r+b$ is a root of $A$.
Since $r-a$ is a root of $B(x)$ and of $A(x+a+b)$, it is also a root of their greatest common divisor $C(x)$ as integer polynomials. If $C(x)$ was a non-trivial divisor of $B(x)$, then $B$ would have a rational root $\alpha$. Since the first and last coefficients of $B$ are 1, $\alpha$ can only be 1 or -1, but $B(-1)=m>0$ and $B(1)=m+2>0$ since $n=2m$.
Therefore, $B(x)=A(x+a+b)$. Writing $c=a+b\ge 1$, we compute
$0=A(x+c)-B(x)=(3c-2m)x^2+c(3c-2m)x+c^2(c-m)$
Then we must have $3c-2m=c-m=0$, which gives $m=0$, a contradiction. We conclude that $f(x)=tx$ is the only solution.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
