Find tangential velocity given radius and the coefficient of friction
The discussion focuses on calculating tangential velocity using centripetal force and friction. The initial approach incorrectly equated centripetal force to gravitational force without considering the role of friction. It was clarified that the normal force, which contributes to centripetal force, must be derived from frictional forces rather than simply using weight. The correct relationship involves setting the frictional force equal to the gravitational force, leading to a revised normal force calculation. This adjustment allows for the accurate determination of tangential velocity.
Send-Help
A student is in a giant trash can which is set on top of a revolving plate. The coefficient of friction between the student and the wall is 0.32, and the can has a radius of 10m. The can is set turning and the floor drops out. How can I find the tangential velocity of the can needed for the student to "stick" to the wall?
Fc = (mv^2)/r, Fn = mg, Ff = Mu (Fn)
I have attempted to solve for the velocity by setting the centripetal force (mv2)/r to the normal force pointed to the center of rotation (mg). This approach seems to give the incorrect solution and I am unsure of my misunderstandings.
:welcome:
Can you post your working? Your method looks correct.
The normal force is horizontal. Gravity is vertical.
Thank you for all the replies. I realized the normal force (also the force making up the centripetal force) cannot simply be accounted for by (mg) but has to be calculated from the frictional forces opposing the force of gravity. This means that (Mu*Fn = mg) which gives Fn=(mg)/Mu; This can be set equal to the centripetal force equation and the correct answer could then be found.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
