hraghav
- 48
- 5
- Homework Statement
- A simple thermometer is formed by taking a large spherical container of volume 1.81m^3 and filling it with an ideal gas. Then, a U-shaped tube is attached that is very narrow so that very little fluid/gas can fit inside the tube. The tube has a small quantity of a fluid of density 2560kg/m^3 placed in it. In equilibrium at room temperature (that is at 24.3∘C) the height of the fluid on both sides of the U-shaped tube are level. This is illustrated in the image below. What is the temperature of the gas in the spherical container when the left side of the fluid is 8.5cm higher than the right side of the fluid in the U-shaped tube? Atmospheric pressure is 101000Pa.
- Relevant Equations
- PV = nRT
P = density*g*h
So first I used the ideal gas law formula PV = nRT to find n using P = 101000Pa, V = 1.81m^3, R = 8.314 J/mol*K^-1, T = 24.3+273.15 = 297.45K. I got n = 73.922 mol.
Then I used P = density*g*h and found P = 2132.48 where density = 2560kg/m^3, g = 9.8 and h = 0.085m.
Then I found total pressure by adding 101000 + 2132.48 = 103132.48
Finally I used the ideal gas law formula PV = nRT again to find T where P = 103132.48, V = 1.81m^3, R = 8.314 J/mol*K^-1 and n = 73.922 mol. I got T = 303.7318K and then converted that to degree C and got 30.58.
But this is not the correct answer and I have attempted this several times but I still can't find the error. Could someone please tell me where am I going wrong?
Thanks a lot for your help! Much appreciated :)
