Find Tension in Cables for 13 kg & 4 kg Signs
  • Thread starter Thread starter awesome_irl
    Cables Tension
The discussion focuses on calculating the tension in four cables supporting a 13 kg and a 4 kg sign. The equations used include force balance in both horizontal and vertical components, leading to the conclusion that the total opposing force is equivalent to the combined weight of the two signs, calculated as 17g. Participants clarify that "g" refers to the acceleration due to gravity (9.8 m/s²) rather than grams. The final calculated tension for T1 is approximately 131.3 N, confirming the accuracy of the calculations. The conversation emphasizes the importance of understanding the forces in equilibrium for a stationary system.
awesome_irl
The big sign below (see attached image) is 13 kg and the small sign is 4 kg. Find the tension in all 4 cables.
Fnet= Fa +Fb
ƩFx= T2cos38 - T1cos51=0
T2=T1cos51/cos38
ƩFy=T1sin51 + (T1cos51/cos38)sin38 - 127.4 -39.2 = 0
T1=131.303
Your T2 is correct.
T3 = T4 = 2g
Fy: T1sin51 + T2sin38 = 17g
this is because the only forces opposing the vertical components of the tensions are the weight of the 13kg and 4kg masses. So the only thing opposing the vertical components of the tension is a combined weight of 17kg which is 17g.
Thanks!
Oh! And merry christmas
Hi, I've updated the post above, which might me helpful to you.
But the forces are in equilibrium and there is no acceleration so how can there be 17g? And won't the opposing forces be the weights, not the masses?
I think this is correct, I get the same:)
Just wondering...was my first attempt correct (my physics teacher posted the answer and her t1 was 131.18 N)
I know I sound paranoid but still... -_-
@ phizkid the "13 g" doesn't denote the mass, I think you mistook the g as a gram rather than the acceleration of gravity. Yoy're correct in mentioning that the system is motionless so that's why the net force is 0 for both the x and y components.
Oh ok then it's all the same
I get T1 = 131.3N
We agree!
"g" is not grams in this case, it is 9.8 m/s2. So by 17g I meant 17 x 9.8m/s2.
