Find Tension in Motorboat Towline: Homework Solution
  • Thread starter Thread starter cturtle
    Tension
The motorboat's engine delivers 30.0 kW while moving at 15.0 m/s, resulting in a force of 2000 N. When towed at the same speed, the tension in the towline should equal this force. The discussion confirms that the force required to maintain the speed remains consistent, regardless of whether the boat is self-propelled or towed. The original poster successfully resolved their question with community assistance. Understanding the relationship between power, force, and speed is crucial for solving similar problems.
cturtle
The engine of a motorboat delivers 30.0 kW to the propeller while the boat is moving at 15.0m/s. What would be the tension in the towline if the boat were being towed at the same speed?
I used P= FV to find F= 2000N, but now I don't know how to find tension. Please help!
Please excuse me if I am wrong, but unless anyone says otherwise, I believe that you have found the answer.
You found the force required to move the boat at 15m/s (F=2kN). So to move that boat at the same speed (15m/s) should require the same amount of force. It's just being applied in a different way.
Thanks so much! I figured it out a little after I posted the question, but thanks for confirming my thoughts!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
