MHB Find the amount of sand in each bag
  • Thread starter Thread starter anemone
The total amount of sand in Bags A, B, and C is 360 g. After a series of transfers, each bag ends up with an equal amount of sand. By working backwards from the final equal amounts, it is determined that Bag C contained 150 g before the last transfer. Consequently, Bag A had 90 g and Bag B had 120 g initially. The problem illustrates a systematic approach to solving for the initial quantities through reverse calculations.
anemone
MHB
POTW Director
Bags $A,\,B$ and $C$ contained 360 g of sand in total. At first, $\dfrac{1}{6}$ of sand in Bag $A$ was poured into Bag $B$. Then, $\dfrac{1}{3}$ of sand in Bag $B$ is poured into Bag $C$. Lastly, $\dfrac{1}{5}$ of sand in Bag $C$ is poured into Bag $A$. In the end, there was equal amount of sand in each bag.
Find the amount of sand in each bag at first.
I haven't been able to solve this problem without setting up equations and solve for the unknowns yet. I'll keep trying, and at the same time want to share this good problem here at MHB.
Mathematics news on Phys.org
Instead of going forward I would go backwards.
Just for notation not algebra let sand in A be a , in B be b, in C be c,
at the end because all are equal we have
a = 120, b = 120, c = 120
In the last step 1/5 of sand in C was poured into A. So in C remained was 4/5 .
now 4/5 is 120 so it was 120 * 5 / 4 or 150 before .
because it was 30 poured from C to A before last step we have
a = 90, b = 120, c = 150
similarly you can calculate other 2 steps.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
