MHB Find the angle X inside a pentagon with a square
  • Thread starter Thread starter mathlearn
    Angle Square
The discussion focuses on finding angle X within a pentagon that includes a square. It establishes that the interior angles of a pentagon total 540 degrees, with each angle in a regular pentagon measuring 108 degrees. The relationship between the angles of the square and the triangle formed by the pentagon's sides is explored, leading to the conclusion that the small angle in the triangle is 18 degrees. By applying the triangle angle sum theorem, the value of angle X is determined to be 81 degrees. The conversation emphasizes the equal lengths of the sides of the square and pentagon, aiding in the calculations.
mathlearn
If the the question is too small , Please be kind enough to read it from here Question
The interior angles of a pentagon add up to 540 degrees. So thinking that this is a regular pentagon with all 5 sides equal an interior would be 108 degrees.
And speaking of the square All four sides are equal and all 4 angles are 0 degrees.
Could have easily found X if the the side with the angle X (shortest side) was a straight line.It could be said using angles on a straight line add up to 180.
But the line seems to be slanted.
I included the information in a diagram,
Any Ideas on How to begin ?
Many Thanks :)
Mathematics news on Phys.org
Hey mathlearn! ;)
Can we already find one of the other angles in the small triangle that contains x?
What kind of triangle is it anyway?
It looks like that side of the pentagon and the side of the square are equal at a glance , But don't know whether it's correct. If I'm correct then it would be an isosceles triangle
Then this will be the result
Many Thanks :)
Many Thanks :)
The sides of the square have the same length.
The sides of the pentagon have the same length.
One side of the square has the same length as the corresponding side of the pentagon.
So yes, those sides are indeed equal. :)
Can we say anything about the small angle in the triangle?
As the interior angles of the pentagon add up to 540 degrees. So One angle should be equal to 108 degrees. Correct I guess ?
:) Yes the small angle of the triangle would be 108(int. angle of the pentagon)=90(int. angle of the square)-(the small angle)
108-90 =small angle
18 degrees = small angle
So 180 (interior angles of a triangle add up to 180 ) = 2x + 18
180 -18 = 2x
162 = 2x
81 = x
Many Thanks :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
