MHB Find the average force required to hold the gun in position
To find the average force required to hold a gun in position while firing, the impulse equation is applied, where force multiplied by time equals mass multiplied by change in velocity. Each bullet has a mass of 3 grams and a speed of 500 m/s, leading to a calculated momentum for one bullet, which is then multiplied by six for the total momentum of all bullets fired per second. Consistent unit conversion is crucial, either converting grams to kilograms for force in Newtons or speed to centimeters per second for force in dynes. Calculating impulse for one bullet over a shorter time frame yields the same force as for six bullets over one second. The discussion also includes a light-hearted side note about typing preferences on mobile devices.
Joe_1234
A gun fires 6 bullets per second into a target. The mass of each bullet is 3g & the speed of 500 m/s. Find the average force required to hold the gun in position.
Mathematics news on Phys.org
Impulse equation ...
$F \cdot \Delta t = m \cdot \Delta v$
Tnx
You titled this "momentum" so it looks like you already knew the basic idea. The momentum of a single bullet is "mass times velocity" and you are given both of those. Of course, the momentum of 6 bullets is 6 times the momentum of a single bullet. Since this all happens in one second, divide by one second to get the force.
Be careful to use consistent units. You are given the mass in grams and the speed in m per second. Either convert mass to kg to get the force in Newtons or convert the speed to cm per second to get the force in dynes. I recommend the former.
calculating the impulse for one bullet over $\Delta t = \frac{1}{6} \text{ sec}$ yields the same result as six bullets in $\Delta t = 1 \text{ sec}$
Joe_1234 said:
Tnx
Serious question - is it harder to type “thanks” or “tnx “ on your phone? On mine the latter will auto correct to something else so it’s actually harder.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
