Find the Central Force on an Electron in a Hydrogen Atom
The discussion focuses on calculating the central force acting on an electron in a hydrogen atom using the Bohr model. The electron's speed is noted as approximately 1.96e+6 m/s, and the radius of its circular orbit is 4.8e-11 m. Participants suggest using Coulomb's law for force calculations, but there is confusion regarding the distinction between central and centripetal forces. The lack of a specified mass for the electron complicates the calculations for some contributors. Ultimately, the conversation emphasizes the need for clarity on the central force concept in this context.
directdelta
In the Bohr model of the hydrogen atom,
the speed of the electron is approximately
1.96e+6 m/s.
Find the central force acting on the electron
as it revolves in a circular orbit of radius
4.8e-11 m. Answer in units of N.
astronuc
thanks astronuc, but that did not help. i was talking about the "central force", not "centripetal" and again, the mass of the particle is not given, so i can't use the mass.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
