Find the distance from the source of power
  • Thread starter Thread starter demonslayer42
    Power Source
A point source power of 100 W produces a decibel reading of 118 dB, leading to a calculated intensity of 0.6309 W/m². The initial attempt to find the distance resulted in a value of 4.471 meters, which did not match the expected intensity. After reviewing the calculations, it was determined that the error occurred in rearranging the formula for distance. The correct distance, using the formula r = sqrt((P/I)/(4π)), is approximately 3.55 meters. Properly applying the logarithmic conversion and rearranging the equation is crucial for accurate results.
demonslayer42
A point source power outputs a power of 100 W. If a decibel reading of 118 dB is heard, what is the distance to the observer.
I = P/(4*pi*r^2)
This should be simple, but for some reason my numbers aren't matching up.
First I converted 118 dB to an intensity of .6309 w/m^2 Then I plug it back into the equation and solve for r which comes out to be 4.471 meters.
So then to check it I put the 4.471 m back into the equation to see if it equals my intensity which it doesn't. I'm not sure where I went wrong on this one. Any help would be greatly appreciated.
What are you using to convert dB to intensity? Are you using the log function correctly?
Yes, I think so. 118 = 10 log (I/Io) Io = 10^(-12) so,
118 = 10 log (I/10^(-12))
11.8 = log (I/10^(-12))
10^(11.8) = (I/10^(-12)
I = 0.6309 w/m^2
Is that correct?
I = 0.6309 w/m^2
Is that correct?
Sorry, that seems fine. Read it wrong the first time.
Right, gone through it properly I get r = 3.55m.
Your values are correct, check how you re-arrange your equation.
I = P / (4*pi*r2)
(4*pi*r2) = P / I
r2 = ((P / I) / 4*pi)
r = sqrt( (P/I) / 4*pi )
omg, I feel so dumb lol yeah that's where I messed up. Instead of (P/I)/(4*pi) I did (P/I*4*pi). Thank you for your help :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
