Find the eigenvectors in the given problem
  • Thread starter Thread starter chwala
chwala
See attached.
Diagonalization of matrices.
Consider this attachment,
In my understanding we have these equations, using P={x,y,z,m], For A.P=0
##24x-12y+4z=0##
##4m=0##
I can see how they got the first one, by letting ##y=0, 24x+4z=0## ⇒##x=1,y=-6## that is clear,
My question is, we can as well have other possibilities other than what is given, correct?
I may as well make ##z=0## to give, ##v_1=\begin{vmatrix}
1 \\
2 \\
0\\
\end{vmatrix}##
##(1,2,0,0)^\tau = v_1+2v_2,## so yes. If ##\{v_1,v_2\}## is a basis, so is ##\{v_1+2v_2,v_2\}.##
There is never only one basis (except one-dimensional ##\mathbb{F}_2## spaces).
There are some typos in the original post.
chwala said:
using P={x,y,z,m]
using ## \textbf{P}=\begin{bmatrix}x&y&z&m\end{bmatrix}^T ##
chwala said:
For A.P=0
For ## \textbf{A}\cdot\textbf{P}=-2\cdot\textbf{P} ##
by letting ## y=0 ##, ## 24x+4z=0 ## ## \implies ## ## x=1 ##, ## z=-6 ## that is clear,
Well, given this is a lower triangular matrix its determinant is the product of the diagonal elements and nonzero, so its kernel is {0}. Or did I miss something?
Given a basis ##B_n; |B_n|=n## and an invertible ##n \times n## matrix M, then ##MB_n## is a basis too.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
