Find the general solution of this nonlinear ODE: xy' + sin(2y) = x^3*sin^2(y)
The discussion revolves around solving a nonlinear ordinary differential equation (ODE) given by xy' + sin(2y) = x^3*sin^2(y). Participants express difficulty in separating variables and finding an exact solution, suggesting that the equation may not be analytically solvable. They explore various substitutions, including Weierstrass and arccotangent, to transform the equation into a more manageable form. Numerical integration is proposed as a potential solution method, but concerns arise about its complexity and the possibility of a typographical error in the problem statement. Ultimately, the conversation highlights the challenges of tackling nonlinear ODEs and the creative approaches needed to find solutions.
Kaguro
Find the general solution of:
All math.
This equation, is non linear, non-separable, and weird. I would like to have a direction to start working on this.
I tried writing sin(2y) = 2sin(y)*cos(y).
See,
##xy' = x^3sin^2(y)-2sin(y)cos(y)##
Can't separate.
Writing in this way:
##(x^3sin^2y-sin2y)dx-xdy=0##
Also, I checked that it is not exact.
So, what next should I try?
Likes Delta2
How about ##\sin(2y)=2\sin(y)\cos(y)=(\sin^2y)'##?
No. I don't see how that helps...
##x\frac{dy}{dx}+\frac{d(sin^2y)}{dy}=x^3sin^2y##
I can hardly take the LCM of dy and dx...
Yes, it's quite tricky. I looked up the solution and the only other idea that gave me is to try a Weierstrass substitution:
https://en.wikipedia.org/wiki/Weierstrass_substitution
Your d.e. is non-linear and not amenable to analytic integration. I think you have two options:
a.) Solve it by numerical integration which could be quite tricky considering the non-linearities involved.
b.) Assume there was a misprint in the problem statement (it happens), and solve the equation:$$
xy' + \sin(2x) = x^3\sin^2(x)$$
Option a.) makes sense if you are in a numerical methods class. Option b.) makes sense if you are in an introductory class for differential equations and the instructor has sloppy handwriting.
Likes Delta2
WolframAlpha had a closed analytic solution. But I don't have the pro version to look up the steps. However, it looks as if Weierstraß could help. Otherwise there is still the option to simply proof that the solution is one by differentiation.
The question was from a daily assignment for a competitive exam. I'm not supposed to do it numerically. But it has a very high probability that there was some typing mistake...(since I'm supposed to be able to solve this question under 4 minutes..)
Also, I've never used Weierstrass substitution...
Do you know the derivative of ##\operatorname{arccot}## by heart?
Yes. I keep getting such integrals to solve, so I need to memorize some of these basic tables by heart.
The solution is ##-\operatorname{arccot}p(x)## with a polynomial in ##x##. So differentiate and see what you can find out about ##p##.
Likes Kaguro and Delta2
Given, y= -arccot(p)
##y' = \frac{p'}{1+p^2}##
##sin(2x) = 2sinxcosx=\frac{2sinx/cosx}{1/cos^2 (x)} =\frac{2tanx}{sec^2 (x)}= \frac{2tanx}{1+tan^2 (x)}##
sin(-2arccot(p)) =-2p/(1+p^2)
similarly, sin^2(x) = tan^2(x)/(1+tan^2(x))
sin^2(-arccotp) = 1/(1+p^2)
So, finally:
##\frac{xp'}{1+p^2} - \frac{2p}{1+p^2} = \frac{x^3}{1+p^2}##
##xp' - 2p = x^3##
##p' - 2p/x = x^2##
Which I solved by integrating factor as 1/x^2.
p = x^3 + Cx^2
Is this ok?
And how on Earth did you find the form of the solution?
Looks good.
I used an internet tool to look up the solution:
https://www.wolframalpha.com/input/?i=xy'=x^3+sin^2(y)+-+2+sin(y)+cos(y)
But that was why I thought the Weierstraß- or half-tangent substitution could help. It is generally a good idea if terms in ##x## and trigonometric functions in ##x## occur, because it turns trig functions into polynomials:
https://de.wikipedia.org/wiki/Weierstraß-Substitution#Beschreibung_der_Substitution
is easier to read than the English version. You only need to look at the formulas.
Likes Kaguro
If you divide the original differential equation by ##\sin^2 y##, you get
$$x y' \csc^2 y = x^3 - \frac{2 \sin y \cos y}{\sin^2 y}.$$ Note that ##y' \csc^2 y = -(\cot y)'##. Now you have a first-order differential equation in ##\cot y##.
Likes fresh_42 and Kaguro
Oh! So that's how one gets the idea to use a trial solution of arccot!
That's great!
You guys are so powerful, manipulating equation in ways unimaginable by me...
  • · Replies 18 ·
  • · Replies 24 ·
