Find the inverse of y=x^3 + x +4
  • Thread starter Thread starter physstudent1
    Inverse
To find the inverse of the function y = x^3 + x + 4, the initial step involves switching the variables to x = y^3 + y + 4. Isolating y proves challenging, as it leads to a cubic equation y^3 + y + 3 = 0. Since this cubic may yield multiple y values for a single x, it indicates that the function may not have a true inverse. Numerical methods, such as the bisection method, can be employed to approximate solutions for specific values, like f^-1(1), by testing intervals to find roots. Ultimately, the complexity of solving cubic equations necessitates careful consideration of the function's behavior to determine invertibility.
physstudent1
I'm helping my friend review for his exam in precalc and I can't seem to get this inverse.
I switched the variables and then tried to isolate the y but I failed.
I ended with x-4=y^3+y I don't know how to isolate the y from here how would you go about it?
you would obtain x=y^3 +y +4, but unless you can find a way to produce an equivalent cubed binomial for the right side, you are stuck. If there are more than one y value for any single x value, then that is not an inverse function.
Given f (x) = x3 + x + 4 , find f -1 (1) accurate to 2 decimal places. Is the exact question I thought I would make it easier by just asking to find the inverse on here...
If you are asking for how to evaluate the inverse of f(x) at x=1, then you want to start with the inverse relationship, x= y^3 + y + 4 [I assume you still meant that the original function was a cubic], and substitute 1=x; and then find the possible values for y. If you obtain two values of y, then the inverse of f(x) is not a function.
1 = y^3 + y + 4
y^3 + y + 3 = 0
Complete the square or use quadratic formula solution;
What is y?
What I said in here (below) is ridiculous. You can't complete the square for a cubic; although you can look for the presence of any x which gives more than one y value.
1 = y^3 + y + 4
y^3 + y + 3 = 0
What is y?
That's a completely different question! In order to solve the equation y3+ y+ 4= x, for any x, you would have to use Cardano's cubic formula- and that's extremely complex!
What you are asked to do here is to use some numerical method to solve the equation y3+ y+ 4= 1 or y3+ y+ 3= 0. A simple way to solve such an equation is "bijection". If y= -2, (-2)3+ (-2)+ 3= -8- 2+ 3= -7< 0. If y= -1, (-1)3+ (-1)+ 3= 1> 0 Since the value at x= -2 is negative and the value at x= -1 is positive, there must be a solution between -2 and -1. Try half way between: -3/2. Is (-3/2)3+ (-3/2)+ 3 positive or negative? Whichever it is, there must be a root between -3/2 and either -2 or -1 depending on which gave the opposite sign. Try half-way between just because it is convenient.
The working out suggests first equating ## \sqrt{i} = x + iy ## and suggests that squaring and equating real and imaginary parts of both sides results in ## \sqrt{i} = \pm (1+i)/ \sqrt{2} ## Squaring both sides results in: $$ i = (x + iy)^2 $$ $$ i = x^2 + 2ixy -y^2 $$ equating real parts gives $$ x^2 - y^2 = 0 $$ $$ (x+y)(x-y) = 0 $$ $$ x = \pm y $$ equating imaginary parts gives: $$ i = 2ixy $$ $$ 2xy = 1 $$ I'm not really sure how to proceed from here.
