Find the Lagrangian of a System of Particles
The discussion focuses on deriving the Lagrangian for a system of two point particles connected by massless levers, rotating about a pivot. The Lagrangian is defined as the difference between kinetic and potential energy, L = T - U, with kinetic energy expressed as T = ½Mv² and potential energy derived from gravitational force, U = Mgh. Participants suggest using cylindrical coordinates to express the velocities of the masses in terms of the angle Θ and angular frequency ω. The potential energy increases with the height z, which is determined to be 2LcosΘ, leading to U = 3LcosΘ*mg. The conversation concludes with the successful formulation of the Lagrangian and the ability to derive equations of motion in the generalized coordinate Θ.
CM Longhorns
Ok, so in this system, there are two point particles of mass M connected by massless levers of length L. The pair of masses pivots about the upper point and rotates about the axis at an angular frequency ω. The lower mass is constrained to slide on the vertical axis. The system is illustrated below:
Find the Lagrangian in terms of Θ.
I know that the Lagrangian is represented by the difference in kinetic and potential energies,
L = T - U
T = ½Mv^2,
and U should be derived from the gravitational force only,
U = Mgh,
where h is the vertical distance from the origin.
I have a fundamental lack of understanding regarding finding the kinetic energy of this system. It has been suggested that I view this in cylindrical coordinates, where
x=LsinΘ
y=LcosΘ
z= z.
I intuit that the origin of my cylindrical coordinate system should reside at the pivot point above the two masses. Could someone please illuminate the subtleties in finding T? I understand conceptually the Lagrangian and the parts of the problem to follow.
Hi CM, and welcome to PF :)
Does U increase if z (h) increases ?
For T you have to express v for each of the masses in terms of ##\theta## and ##\omega##. x and y you already have, so ##\dot x## and ##\dot y## aren't too difficult. You will have to do something about z, though. I can see that if ##\theta## is given, z is determined; i.e. there is a way to express z in terms of ##\theta##
I worked out this problem in the mean time. You are correct!
I see that the potential increases with z, which can be determined to be 2Lcosθ.
The gravitational potential energy is thus U = 3Lcosθ*mg when we account for g's effect on each mass.
The kinetic energy I have determined as well.
Then, L = T - U, and voila, we have a Lagrangian! I can now find the equation of motion in the generalized coordinate θ.
Thanks for your help; hope to see you here again :)
However, your expression for U decreases when ##\theta## increases from zero. I would expect it to increase; wouldn't you ?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
