Find the Mass of Ice Needed to Cool 800mL Water to 0.0°C
To cool 800 mL of water from 28°C to 0.0°C using ice at 0.0°C, the mass of ice needed can be calculated using the formula Q = mc(delta)T. The specific heat capacity of water is 4.184 J/g K, and the temperature change (delta T) is -28°C. The mass of the water can be determined by using the density of water, which is 1000 kg/m³, to convert the volume to mass. The total energy required to cool the water must equal the energy absorbed by the melting ice. This approach will yield the mass of ice necessary to achieve the desired temperature.
cstout
Ice at 0.0°C is mixed with 8 × 102 mL of water at 28°C. How much ice must melt to lower the water temperature to 0.0°C?
Q = mc(delta)T
c = 4.184 J/g K
(delta)T = -28C
V = 800 mL
I'm not sure what to do since the volume is given and not the mass in this problem.
HINT: What is the density of water?
ok, but now how do you find how much ice is needed? when density = mass/v and the density of water is 1000kg/m^3 =mass / 800mL
You first need to work out how much energy is required to change the temperature of 816 mL of water by 28oC.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
