MHB Find the Modulus & Argument of \(wz\)
The complex numbers \(w\) and \(z\) have been expressed in Cartesian form as \(w = -1 - i\) and \(z = 1 - i\sqrt{3}\). Their product \(wz\) results in \((-1 - \sqrt{3}) + i(-1 + \sqrt{3})\). The modulus of \(wz\) is calculated as \(\sqrt{(-1 - \sqrt{3})^2 + (-1 + \sqrt{3})^2}\), yielding a specific value. The argument can be determined using the arctangent function based on the real and imaginary parts, leading to the exact angle for \(wz\). This process illustrates the multiplication of complex numbers and the conversion between polar and Cartesian forms.
Punch
The complex number w has modulus \(\sqrt{2}\) and argument \(-\frac{3\pi}{4}\), and the complex number \(z\) has modulus \(2\) and argument \(-\frac{\pi}{3}\). Find the modulus and argument of \(wz\), giving each answer exactly.
By first expressing w and \(z\) is the form \(x+iy\), find the exact real and imaginary parts of \(wz\).
I have a problem with finding the argument of \(wz\) and expressing \(w\) and \(z\) in the form \(x+iy\)
Mathematics news on Phys.org
Re: complex numbers
Punch said:
The complex number w has modulus \sqrt{2} and argument -\frac{3\pi}{4}, and the complex number z has modulus 2 and argument -\frac{\pi}{3}. Find the modulus and argument of wz, giving each answer exactly.
By first expressing w and z is the form x+iy, find the exact real and imaginary parts of wz.
I have a problem with finding the argument of wz and expressing w and z in the form x+iy
Review how to multiply two complex numbers when they are written in polar form.
z = r cis(theta). You need to review polar form.
If you need to solve this problem by converting to Cartesians, then
\[ \displaystyle \begin{align*} w &= \sqrt{2}\left[\cos{\left(-\frac{3\pi}{4}\right)} + i\sin{\left(-\frac{3\pi}{4}\right)}\right] \\ &= \sqrt{2}\left(-\frac{1}{\sqrt{2}} - \frac{i}{\sqrt{2}}\right) \\ &= -1 - i \end{align*} \]
and
\[ \displaystyle \begin{align*} z &= 2\left[\cos{\left(-\frac{\pi}{3}\right)} + i\sin{\left(-\frac{\pi}{3}\right)}\right] \\ &= 2\left(\frac{1}{2} - \frac{i\sqrt{3}}{2} \right) \\ &= 1 - i\sqrt{3} \end{align*} \]
So multiplying them together gives...
\[ \displaystyle \begin{align*} wz &= \left(-1-i\right)\left(1-i\sqrt{3}\right) \\ &= -1 + i\sqrt{3} - i + i^2\sqrt{3} \\ &= \left(-1 - \sqrt{3}\right) + i\left(-1 + \sqrt{3}\right) \end{align*} \]Can you evaluate the modulus and argument of this complex number?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
