Chemistry Find the molecular and empiral formula
  • Thread starter Thread starter tommyjohn
    Formula Molecular
Digiton, a substance used to determine cholesterol levels, has a percent composition of 54.71% carbon, 7.54% hydrogen, and 37.74% oxygen. The empirical formula was calculated as C10H15O5 after determining the moles of each element and simplifying. The molecular mass of Digiton is 1229 g/mol, leading to a calculated empirical mass of 215 g. Dividing the molecular mass by the empirical mass suggests a multiplier of approximately 5. The final molecular formula is likely C50H75O25, derived from multiplying the empirical formula by 5.
tommyjohn
Digiton is a substance that technologists use to determine cholesterol levels. It contains only (C,H, and O) and its percent composition is 54.71% C, 7.54% H, and 37.74% O by mass. The experimentally determined molecular mass is 1229g/mol. What is the empirical amd molecular 1 formula for digiton?
ok so C=12g, H=1g and O=16g
First,
54.71/12= 4.56 mol
7.54/1= 7.54 mol
37.74/16= 2.36 mol
Secondly, I got to divide by the smallest number which in this case is 2.36
4.56/2.36= 1.9~2
7.54/2.36= 3.2
2.36/2.36=1
since 3.2 is to far away i multplied it by 5 to get a number that i can round. My end solution for the empirical formula was C10H15O5.
Now to get the molecular i found the grams in the empirical which was 215g. Now 1229/215=5.7 which i THINK i have to get a whole number and it took me x3 to get 17.1 which can be rounded to 17. So I am stuck on to what to do in finding the molecular formula if everything above this is right which I am fairly confident it is.. please help
You may want to attempt solving for the molecular formula first--you're given all the information necessary to calculate moles of each element per mole of compound.
Then divide by the greatest common factor to get the empirical formula.
Empirical formula should contain lowest possible numbers. 5, 10 and 15 are all multiplies of the same smaller number.
9K
  • · Replies 100 ·
13K
14K
