Chemistry Find the molecules by interpreting the H NMR spectroscopy
The discussion focuses on interpreting H NMR spectroscopy to identify three compounds with the formula C6H12O2. Users analyze the integration ratios from the spectra, noting degrees of unsaturation for each graph. The first spectrum shows a 2:3:2:2:3 ratio, the second a 1:3:2:3:3 ratio, and the third a simpler 1:3 ratio. The challenge lies in determining the connectivity of the protons based on these integrations. Ultimately, the user successfully deduces the structures after careful consideration of the NMR data.
STLCards002
I have a 3 compounds with the same formula: C6H12O2
I need to find the molecules by interpreting the H NMR spectroscopy
http://aceorganic.pearsoncmg.com/epoch-plugin/tempfiles/1867_430.jpg
http://aceorganic.pearsoncmg.com/epoch-plugin/tempfiles/1869_524.jpg
http://aceorganic.pearsoncmg.com/epoch-plugin/tempfiles/1871_526.jpg
[/B]
I've tried so many structures that it would be pointless to name them off.
Don't start with structures - start with the spectrum. What does integration tell you about number of hydrogens? What does formula tell about saturation?
Well I know (atleast I think) the integrations;
1st graph: 2:3:2:2:3; One degree of unsaturation
2nd graph: 1:3:2:3:3; One degree of unsaturation
3rd graph: 1:3; One degree of unsaturation
But then I can't put everything together. I spend atleast an hour one each of these but can't figure out there connectivity.
3rd seems to be the simplest. 1:3 - you have two types of protons. How many of each type?
Each spike counts as 3 Hydrogens...so a CH3 and then 4 CH3?
I figured them out. Thanks for the help.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
