Find the position of a pendulum as a function of time?
To find the position of a pendulum as a function of time, the equation f(t) = 0.35cos(1.81t) is derived, where 0.35 represents the initial displacement from equilibrium. The period of the pendulum is calculated using T = 2π√(l/g), which helps determine the frequency. The value 1.81 is related to the angular frequency, derived from the pendulum's length and gravitational acceleration. The discussion highlights confusion regarding the interpretation of displacement and the relationship between the angle and the pendulum's motion. The thread concludes with the user expressing clarity on the topic, indicating a resolution to their confusion.
Camphi
How do you find the position of a pendulum as a function of time?
Mass of bob: 2.0kg
String length (l): 3.0m
The pendulum is displaced as a distance of 0.35m from the equilibrium point and is then released. After 100 swings the maximum displacement of the pendulum has been reduced to 0.15m.
[/B]
Period (T) of a pendulum: T = 2π√(l/g)
The answer to the problem is f(t) = 0.35cos(1.81t) but I am not understanding how the 0.35 or the 1.81t is coming into play because I figured that if the angle is the point where the equilibrium point and the place where the pendulum is attached to a wall then the 0.35 would be opposite of this angle, not the adjacent of hypotenuse of the triangle created from the displacement of the pendulum. I also figured that the 0.35 was what the displacement was and I do not understand where the 1.81 came from at all.
I have had an epiphany so moderators can lock this thread.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
