Find the power series in x-x0?
Math10
Find the power series in x-x0 for the general solution of y"-y=0; x0=3.
None.
Let me post my whole work:
What I did was the substitution method using z=x-x0.
The answer for this problem is
None.
No, please don't. The PF standard is for you to type out the problem and the solution, reserving images for things like diagrams or geometric constructions, etc.
I know that some helpers answer questions about handwritten solution images, but most will not bother. You should consult the pinned post "guidelines for Students and Helpers", by Vela, for a good explanation about this and similar issues.
Can you please take a look at the work that I posted? It's clearly written.
It looks like the right answer in post #2, if that's all you are asking.
I know that's the right answer, but what should I do to get to the right answer after the last step in my work? That's where I got stucked.
You need to spot a pattern in the coefficients (and verify it by induction if need be). You can see from the answer that you need to separate ##n## even and odd.
You mean this:
n=2m (even index)
a2m+2=a2m/[(2m+2)(2m+1)]
n=2m+1 (odd index)
a2m+3=a2m+1/[(2m+3)(2m+2)]
Math10 said:
You mean this:
n=2m (even index)
n=2m+1 (odd index)
Yes, but can you see the pattern? The answer gives you a big clue!
So how do I get to the answer? I know where x-3 comes from.
You get to the answer by noticing that ##1 \times 2 \times 3 \times \dots \times n = n!##
The clue was that the answer has ##n!## in it.
I still don't really get it.
You have:
##(n+2)(n+1)a_{n+2} = a_n##
Hence:
##a_{n+2} = \frac{a_n}{(n+2)(n+1)}##
For ##n## even this gives:
##a_2 = \frac{a_0}{2}, \ a_4 = \frac{a_2}{12} = \frac{a_0}{24}, \ a_6 = \frac{a_4}{30} = \frac{a_0}{720} \dots##
And, now by insight, inspiration (or looking at the answer) you have to notice that ##2, 24, 720 \dots## are the even factorials and hence ##a_n = \frac{a_0}{n!}##
Odd ##n## is much the same.
Likes Math10
I got it now. Thank you so much.
PeroK said:
You have:
Hence:
This thread is in the Homework Help forums...
