MHB Find the Range of a Rational Function.
  • Thread starter Thread starter mathdad
To find the range of the rational function y = 1/x algebraically, one must first determine its inverse, which is also y = 1/x. The domain of this inverse is all real numbers except zero, indicating that the range of the original function is also all real numbers except zero. This means that y can take any value in the real numbers, excluding zero. The discussion also briefly touches on a similar function, g = 1/x^2, which has the same domain but a different range. The overall conclusion is that the range of y = 1/x is all real numbers except zero.
mathdad
Find the range of y = 1/x algebraically.
Steps
1. Find the inverse y = 1/x.
2. Find domain of inverse of y = 1/x.
3. The domain of the inverse is the range of the original function given.
Correct?
Mathematics news on Phys.org
To be a bit more precise (perhaps with an eye towards calculus and analysis), let's talk about the function $f : x \mapsto y = \frac{1}{x}$ with domain $\mathbb{R} \setminus \{0\}$ and co-domain $\mathbb{R}$.
This means that $f$ assigns to every non-zero real number $x$ the real number $y = \frac{1}{x}$.
RTCNTC said:
Steps
Yes, here that works, because $f$ is indeed invertible. In general, you need to determine those real numbers $y$ for which the equation $f(x) = y$ has at least one nonzero solution $x$, i.e. those $y \in \mathbb{R}$ for which $\frac{1}{x} = y$ has at least one solution $x \in \mathbb{R} \setminus \{0\}$.
Yes, for this particular $f$ this is equivalent to what I wrote above.
Correct?
Yes, with the remarks above.
For example, can you do the same question for $g : x \mapsto y = \frac{1}{x^2}$, again with domain $\mathbb{R} \setminus \{0\}$ and co-domain $\mathbb{R}$?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
