MHB Find the smallest possible degree of a polynomial
  • Thread starter Thread starter anemone
    Degree Polynomial
The discussion revolves around determining the smallest possible degree of the polynomial m(x) derived from the expression d^{1992}/dx^{1992}(h(x)/(x^3-x)), where h(x) is a nonzero polynomial of degree less than 1992 and has no common non-constant factors with x^3-x. Participants analyze the implications of the degree of h(x) and the structure of the rational function formed by h(x) and x^3-x. The key focus is on the differentiation process and how it affects the degree of the resulting polynomial m(x). Ultimately, the goal is to find the minimum degree of m(x) under the given conditions. The discussion emphasizes the relationship between the degrees of the involved polynomials and the differentiation operation.
anemone
MHB
POTW Director
Let $h(x)$ be a nonzero polynomial of degree less than 1992 having no non-constant factor in common with $x^3-x$. Let
$\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{h(x)}{x^3-x}\right)=\dfrac{m(x)}{n(x)}$
for polynomials $m(x)$ and $n(x)$. Find the smallest possible degree of $m(x)$.
Mathematics news on Phys.org
Hint:
Rewrite $h(x)=(x^3-x)q(x)+r(x)$ and partial fraction decomposition of a certain rational function might be very useful as well.
Hint:
Let $h(x)=(x^3-x)q(x)+r(x)$ where $q(x)$ and $r(x)$ are polynomials, the degree of $r(x)$ is less than 3, and the degree of $q(x)$ is less than 1989, then
$\begin{align*}\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{h(x)}{x^3-x}\right)&=\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{r(x)}{x^3-x}\right)\\&=\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{A}{x-1}+\dfrac{B}{x}+\dfrac{C}{x+1}\right)\end{align*}$
That's all I can give as today's hint.:)
Solution of other:
Because $h(x)$ and $x^3-x$ have no non-constant common factor, neither do $r(s)$ and $x^3-x$, therefore, $ABC\ne 0$.
Thus,
$\begin{align*}\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{h(x)}{x^3-x}\right)&=\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{r(x)}{x^3-x}\right)\\&=\dfrac{d^{1992}}{dx^{1992}}\left(\dfrac{A}{x-1}+\dfrac{B}{x}+\dfrac{C}{x+1}\right)\\&=1992!\left(\dfrac{A}{(x-1)^{1993}}+\dfrac{B}{x^{1993}}+\dfrac{C}{(x+1)^{1993}}\right)\\&=1992!\left(\dfrac{Ax^{1993}(x+1)^{1993}+B(x-1)^{1993}(x+1)^{1993}+Cx^{1993}(x-1)^{1993}}{(x^3-x)^{1993}}\right)\end{align*}$
Since $ABC\ne 0$, it's clear that the numerator and denominator have no common factor. Expanding the numerator gives an expression of the form
$(A+B+C)x^{3986}+1993(A-C)x^{3985}+1993(996A-B+996C)x^{3984}+\cdots$
From $A=C=1$, $B=-2$, we see the degree can be as low as 3984. A lower degree would imply $A+B+C=0$, $A-C=0$, $996A-B+996C=0$, implying that $A=B=C=0$, a contradiction.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
