Find the speed of the bird relative to the ground
The discussion revolves around calculating the speed of a bird relative to the ground as it moves in a spiral pattern while rising. The bird completes a circular path with a radius of 8.00 meters every 5.00 seconds and ascends at a rate of 3.00 m/s. Participants express confusion over the correct interpretation of "speed relative to the ground," debating whether it refers to vertical speed or overall speed including horizontal motion. The horizontal component of the bird's velocity needs to be calculated using the circumference of the circle, which is essential for finding the total speed. Clarification on the correct equations and components is sought to resolve the confusion.
devilsangels287
It is common to see birds of prey rising upward on thermals. The paths they take may be spiral-like. You can model the spiral motion as uniform circular motion combined with a constant upward velocity. Assume a bird completes a circle of radius 8.00 every 5.00 and rises vertically at a rate of 3.00 .
Find the speed of the bird relative to the ground.
Find the magnitude of the bird's acceleration.
Find the direction of the bird's acceleration.
Find the angle between the bird's velocity vector and the horizontal.
I used the relative velocity equation:
vector velocity = vector v' + Vector V
I plugged in
vector velocity = 3 + (8/5) then I got the answer 4.6 m/s which is incorrect. I thought that this would be the right answer but its not.
So since this is wrong, the other parts wouldn't work either.
Thanks for helping!
I'm a little confused by "speed of the bird relative to ground"... are they asking for the rate at which the height is changing (in this case the answer is just 3.00m/s)... or are they asking for the speed relative to a fixed position on the ground?
In the second case there are two components to the velocity... the vertical component and the horizontal component... The vertical component is 3.00m/s.
What is the horizontal component? it isn't 8/5... what is the circumference of a circle?
I have no idea what it is asking for? I tried the second case of your idea and it wasn't right also. Do you know if the equation that I used was correct?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
