Find the sum of the first 17 terms of the arithmetic series
In summary, we are finding the sum of the first 17 terms of an arithmetic series with a common difference of $-(2+\sqrt{7})$. We can use the formula $S_n=\frac{n}{2}(2a_1+(n-1)d)$ to find the sum. Substituting in the values of $a_1=8+\sqrt{7}$, $d=-(2+\sqrt{7})$, and $n=17$, we get a simplified expression of $\sqrt{7}+104$ as the sum.
karush
MHB
3,269
$$8+\sqrt{7}, \ 6,\ 4-\sqrt{7}$$
$$u=8+\sqrt{7}$$
$$S_{17} =\frac{u\left(1-\frac{{6}^{17}} {u} \right)}{u}$$
My first shot at this
Mathematics news on Phys.org
Can you post the question as given?
Common difference, $d$: $-(2+\sqrt7)$
General term: $a_k=a_1+d(k-1)$
Sum: $\dfrac k2(a_1+a_k)$
We may write:
\(\displaystyle S_n=a_1+a_2+a_3+\cdots+a_{n-2}+a_{n-1}+a_{n}\)
Since we have an AP, and if we write the common difference as $d$, we may rewrite this as:
\(\displaystyle S_n=a_1+(a_1+d)+(a_1+2d)+\cdots+(a_1+(n-3)d)+(a_1+(n-2)d)+(a_1+(n-1)d)\)
By the commutative property of addition, we may rewrite this as:
\(\displaystyle S_n=(a_1+(n-1)d)+(a_1+(n-2)d)+(a_1+(n-3)d)+\cdots+(a_1+2d)+(a_1+d)+a_1\)
Adding these two equations, by corresponding terms, we obtain:
\(\displaystyle 2S_n=n(2a_1+(n-1)d)\)
\(\displaystyle S_n=\frac{n}{2}(2a_1+(n-1)d)\)
This is equivalent to the formula given by greg1313.
In the given problem, we know:
\(\displaystyle a_1=8+\sqrt{7},\,d=-(2+\sqrt{7}),\,n=17\)
$$S_{17}=\frac{17}{2}
\left(2\left(8+\sqrt{7}\right)
+\left(17-1\right)
(-\left(2+\sqrt{7}\right)) \right)$$
Hopefully
+\left(17-1\right)
Hopefully
You will want to simplify by distributing/combining like terms, etc. :)
+\left(17-1\right)
(-\left(2+\sqrt{7}\right)) \right)=\sqrt{7}+104$
I get:
\(\displaystyle S_{17}=-17(8+7\sqrt{7})\)
FAQ: Find the sum of the first 17 terms of the arithmetic series
What is an arithmetic series?
An arithmetic series is a sequence of numbers where the difference between consecutive terms is constant. For example, 2, 5, 8, 11, 14 is an arithmetic series with a common difference of 3.
How do I find the sum of the first 17 terms of an arithmetic series?
To find the sum of the first 17 terms of an arithmetic series, you can use the formula S = (n/2)(2a + (n-1)d), where S is the sum, n is the number of terms, a is the first term, and d is the common difference. In this case, n = 17, a is the first term of the series, and d is the common difference.
What is the formula for the sum of an arithmetic series?
The formula for the sum of an arithmetic series is S = (n/2)(2a + (n-1)d), where S is the sum, n is the number of terms, a is the first term, and d is the common difference.
Can I find the sum of an infinite arithmetic series?
Yes, you can find the sum of an infinite arithmetic series if the series is convergent. The formula for this is S = a/(1-r), where S is the sum, a is the first term, and r is the common ratio.
Can an arithmetic series have a negative common difference?
Yes, an arithmetic series can have a negative common difference. This means that the terms in the series are decreasing instead of increasing. For example, 10, 7, 4, 1 is an arithmetic series with a common difference of -3.
