Find the tension in each string
  • Thread starter Thread starter mechanics_boy
    String Tension
To find the tension in three strings supporting a 5.00 kg mass, the weight (w) is calculated as 50 N using the formula w = mg. The challenge lies in determining the tensions in strings T1 and T2, with the hint suggesting to consider the equilibrium at the junction of the strings. A free body diagram is recommended to visualize the forces and their components. The user realized that overlooking vector components was the key mistake, leading to a clearer understanding of the problem. This approach ultimately helped in solving for the tensions in all three strings.
mechanics_boy
A mass of 5.00 kg hangs attached to three strings as shown in the figure (see image below). Find the tension in each string. Hint: Consider the equilibrium of the point where the strings join.
W=mg
Well finding the tension in string 3 (T3) was relatively easy:
w=mg
mass of the block = 5.00 kg
g = 10 ms-2
w = 5.00 x 10 = 50 N
It is the other two (T1 and T2) I'm not sure. In fact I'm at lost with what I learned in class and applying. I noticed the problem states a hint (equilibrium where strings join) but I'm not seeing how this information can be used.
**LINK TO THE PICTURE**: http://postimage.org/image/63m5xydbj/
W=mg
w=mg
g = 10 ms-2
[PLAIN]http://postimage.org/image/63m5xydbj/[/QUOTE]
First, I'll display the image, although it's of a fairly poor quality.
Draw a free body diagram for the point at which the three strings meet.
Thank you Sammy. I noticed what I had done wrong, I ignored to look at the vectorial components. After that, the rest unfolded easily. Thanks again :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
