Narroo
- 15
I'm preparing for the GRE, and I've encountered a practice problem that I can solve, but not in a manner practical for the test.
Two spaceships approach Earth with equal speeds,
as measured by an observer on Earth, but from
opposite directions. A meterstick on one spaceship
is measured to be 60 cm long by an occupant
of the other spaceship. What is the speed of each
spaceship, as measured by the observer on Earth?
(A) 0.4c
(B) 0.5c
(C) 0.6c
(D) 0.7c
(E) 0.8c
Well, the problem seems easy. And it is: Start with length contraction followed by Einstein Velocity Addition:
Length Contraction
[itex]\acute{d}=\frac{d}{\gamma}[/itex]
[itex]\acute{V}=\frac{V_{1}+V_{2}}{1+\frac{V_{1}V_{2}}{C^{2}}}[/itex]
Well, I did what you would expect. I first solved for the velocity of the two spaceships relative to each other. This gives [itex]0.8c[/itex]. But, you need the speed of the ship relative to the Earth! So I used the addition formula. This gives [itex]0.5c[/itex], which is the correct answer!
So, the problem? This is a GRE question. I don't have a calculator or that much time to solve the question.
When you do the math, After a fair amount of algebraic manipulation, the final equation looks like this:
[itex]v^{4}+2(1-2 \frac{d^{2}}{\acute{d^{2}}})v^{2}+1=0[/itex]
And that's before throwing in the quadratic equation!
Of course, you can just calculate [itex]\acute{v}[/itex] and just solve
[itex]\acute{V}=\frac{2v}{1+\frac{v^{2}}{C^{2}}}[/itex], but that still ends in a quadratic equation and a lot of arithmetic. It's not a practical solution.
I've tried manipulating the equations to create a simple, easy, equation to solve, to no luck. What do you think?
(A) 0.4c
(B) 0.5c
(C) 0.6c
(D) 0.7c
(E) 0.8c
Length Contraction
