Find volume of solid rotated about X axis Washer method
2.7taudi
y=x^2+1
X in (0,1)
formula needed
integral (PI [f(x)]^2 DX
in the F(x) just plug in the equation right?
took anti deritive of the original problem and came out with
PI[1/3x^3+X]^2
my answer is 5.58
am i on the right track?
im confused on the squared part. Do i take the Anti deritive of the squared or only the thing inside the brackets?
Right, you plug f(x) into the formula, but that ^2 means you square f(x), so [f(x)]^2 = (x^2 + 1)^2. That's what you actually want to integrate.
So how do i take the Anti deritive of that?
is it 1/3(x^2+1)^3*(1/3x^3+X)^2? I am going blank lol should there be a ^2 at the end of that?
That wouldn't be the way to integrate it
Easiest way would probably be to multiply it out,
(x2+1)2 = (x2+1)(x2+1) = ...
then integrate each term.
Got it!
does this look right? excuse my chicken scratch handwriting.
Yep, that's it!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
