MHB Finding 2D Polygon Coordinates from a point
To find the coordinates of a polygon with n sides centered at a point (x, y) with a radius r, the equations for each vertex are x + r cos(2πk/n) and y + r sin(2πk/n), where k ranges from 0 to n-1. This ensures all points are equidistant from the center point, lying on a circle of radius r. The first vertex will be positioned to the right of (x, y) when k=0. If a different starting position is desired, a constant can be added to the cosine and sine functions. These equations provide a straightforward method for generating polygon coordinates based on user input.
Krotus
Suppose that I have the coordinates of x and y on a plane.
I am writing a piece of software where the user can select a polygon of 3, 4, 5, 6 or 8 sides. All of the polygon points are equidistant from the x, y point. In other words, if you drew a circle where the center was the x, y point, all of the points of the polygon would line on the circle.
That means, obviously, that the distance of each polygon point is equal to the imaginary circle's radius.
Given that information, what are the equations to create each type of polygon's set of points?
Mathematics news on Phys.org
Hi Krotus, welcome to MHB!
Suppose the polygon will have $n$ sides.
And suppose each of the polygon points must have a distance of $r$ to point $(x,y)$.
Then the x- and y-coordinates of point $k$ of the polygon are given by:
$$\begin{cases}x + r \cos(2\pi \cdot k/n) \\ y + r\sin(2\pi \cdot k/n)\end{cases}$$
where $k$ runs from $0$ to $n-1$. Furthermore, the first point ($k=0$) will be to the right of $(x,y)$.
If you want the first point to be in a different location than to the right of $(x,y)$, we can add a fixed constant to the calls of $\cos$ and $\sin$.
Thanks! Very simple. I knew I had to be overthinking it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
