MHB Finding a particular angle withion Johnson Solid J2
  • Thread starter Thread starter GreyArea
    Angle Solid
The discussion focuses on calculating a specific angle in the Johnson Solid J2, a pentagonal pyramid. The angle in question is formed by a vertical line from the apex to the base and a line bisecting one of the equilateral triangular faces. The user has identified the formulas for the slant height and the height of the pyramid, concluding that the angle can be determined using cosine. After calculations, the angle is found to be approximately 52.62263 degrees, which remains constant regardless of the triangular face length. This insight provides a valuable solution for others encountering similar geometric challenges.
GreyArea
MY apologies that I don't think this is particularly advanced; my algebra and trigonometry is quite good, but all seems to fall apart once i move from 2D to 3D environments.
Johnson Solid J2 is a pentagonal pyramid consisting of five equilateral triangles on a pentagonal pase, meeting at the apex. It's the shape you get if you slice off the top five triangular faces of an icosahedron.
I can find a lot of info on this shape, height, surface area etc, but I need to know one specific angle that eludes me; the angle formed by the junction of;
1. A vertical line dropped from the apex of the solid to the base
2. a line that bisects one of the equilateral triangles, rising from the mid point of base of the triangle to its apex
If it can be calculated as a function of the height of the pyramid, or the height of the face that's fine, but I get the feeling it SHOULD be a constant value, similar to the dihedral angle of (approx) 138 .2 degrees that is formed by the junction of any pair of triangular faces in this solid.
Thanks for your help!
Mathematics news on Phys.org
As is often the case...I get stuck, post for help...then get lucky!
I've found the formula for the "slant height" (a term I did not previously know) which is the length of the bisecting line down the midpoint of the face.
Since I already have the formula for the height of the pyramid, I believe I have everything I need to find the angle as follows;
a = length of edge of face.
Slant height (s)
$$0.5 * \sqrt{3} * a$$
Pyramid height (h)
$$sqrt{((5 - sqrt{5})/10)} * a$$
So if I'm right, s is my hypotenuse, h my adjacent...so I just need to use cosine?
I could probably substitute and simplify given time...but when Excel is so easy...the answer should anyone ever need it, is 52.62263 degrees and as I suspected does not vary with the length of the triangular faces.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
10K
