Finding accleration of object after collision
In a discussion about the acceleration of two basketball players after a collision, Player 1, with a mass of 55.0 kg, has an acceleration of -15.6 m/s². To find Player 2's acceleration, the net force on Player 1 is calculated using F=ma, resulting in a force of -858 N. Applying Newton's Third Law, the force exerted by Player 2 on Player 1 is equal and opposite to the force exerted by Player 1 on Player 2. This leads to the calculation of Player 2's acceleration as -17.6 m/s², indicating the direction of forces and accelerations post-collision. Understanding these dynamics is crucial for resolving similar physics problems effectively.
Adam17
1. Two basketball players collide. Player 1, with a mass of 55.0 kg, experiences a -15.6 m/s2 acceleration. If player 2 has a mass of 48.5 kg, what acceleration did he experience immediately following the collision?
F=ma
I am doing a correspondance course and I don't understand how to figure this out... don't need a solution but just directions on how to solve this.
Welcome to PF,
You know the net force on player 1, because you know his mass, and you know his acceleration. (See Newton's 2nd law).
Now apply Newton's Third law to the problem. What does it say is the relationship between the force on player 1 due to player 2 (which you know), and the force on player 2 due to player 1 (which you need to know)?
Ok thanks for your help. Glad I found this forum though or else Id have to wait till monday to talk to my teacher and I need this course done asap.
So this is what I got and I am confident that it is correct, however I am unsure about the negative. Would the force that I calculated from player 1 be in the same direction as the acceleration
?(away from the collision) Making the Force applied to player 2 positive?
F=ma
Fp1=55(-15.6)
Fp1=-858
A=f/m
Ap2=-858/48.5
Ap2=-17.6m/s^2
The negative force is the force player 2 exerts on player 1, not the force player 1 exerts on player 2.
Xisune said:
The negative force the force player 2 exerts on player 1, not the force player 1 exerts on player 2.
Ohhhh right. Thanks Xisune.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
