Finding Angle of Vectors in 2D Space
  • Thread starter Thread starter lim
    Angles Vectors
To find the y-component of a vector in the x-y plane with a magnitude of 86.4 and an x-component of 62.3, the correct y-component is 59.9. The angle calculated using the sine function, Sin-1(Vy/|v|), yielded 43.85°, which was incorrect, suggesting the vector may not be in the first quadrant. The discussion indicates that if the angle is in the fourth quadrant, it would be represented as -43.85° when measured clockwise from the x-axis. The participants clarify that the angle should be adjusted based on the quadrant, and they explore the implications of the vector's position on its angle. Understanding the correct quadrant and angle representation is crucial for accurately determining the vector's orientation.
lim
What is the y-component of a vector in the x-y plane whose magnitude is 86.4 and whose x-component is 62.3?
59.9
a^2 + b^2 = c^2
Sin-1= Vy/|v|
a^2 + b^2 = c^2
And 59.9 was right for that, but
i used Sin-1= Vy/|v| for the angle and got:
Sin-1= 59.86/ 86.4
= 43.85°
but that wasn't right.
Can anyone offer me some insight?
Hmm strange. Perhaps the vector is not in the first quadrant if the angle 43.85 degrees is not right.
See what is the correct answer if it is supplied and work your way back to understand it.
From the question it looks like X is positive so the angle is either in the first or fourth quadrant.
Oh, it also said to find the angle with respect to the x -axis, if that clarifies. So if it is in the fourth quadrant the angle would be negative?
Yes if you are looking clockwise and if the angle is indeed in the fourth quadrant which is the most likely answer your calculator will give you.
If you still not understand, post the answer your book tells you and I will try to decode it for you.
Well, we submit our answers online and it only tells us if it's right or wrong. But -43.85 was also incorrect, so should I be adding like 90° or 180° to it? As if it was trying to find the angle around it, and not the angle itself?
Two vectors have a magnitude of 86.4 and an x coomponent of 62.3:
In the first quadrant (62,3, 59.9)
In the fourth quadrant (62.3, -59.9)
Their polar coordinates are:
In the first quadrant (86.4, 43.86 degrees)
In the fourth quadrant (86.4, -43.86 degrees)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
