Finding $\angle PCA$ in Triangle ABC with $\angle ANB = 90^\circ$
In summary: Then by the Law of Sines:$\frac{\sin{\theta_5}}{AN}=\frac{\sin{\theta_6}}{BN}$$\frac{\sin{\theta_4}}{AN}=\frac{\sin{\theta_3}}{CN}$$\frac{\sin{\theta_3}}{BN}=\frac{\sin{\theta_5}}{CN}$Also, by the Law of Cosines:$z^2=x^2+y^2-2xy\cos{\theta_6}$$x^2=z^2+y^2-2yz\cos{(90^\circ-\alpha)}$$y^2=z^2+x^2-2zx\cos
maxkor
84
In triangle ABC point $N \in BC$ , point $P \in AN$. Let
$\angle ANB = 90$°
$\angle PBA = 20$°
$\angle PBC = 40$°
$\angle PCB = 30$°.
Find $\angle PCA$.
I don't know how to solve that. Maby it was.
Mathematics news on Phys.org
Let's begin by constructing a diagram:
\begin{tikzpicture}[blue]
\coordinate (A) at (0,0);
\coordinate (B) at (2,5);
\coordinate (C) at (8,0);
\coordinate (N) at (3.28,3.93);
\coordinate (P) at (2,2.4);
\draw[blue, ultra thick] (A) -- (B) -- (C) -- cycle;
\draw[blue, ultra thick] (A) -- (N);
\draw[blue, ultra thick] (B) -- (P);
\draw[blue, ultra thick] (P) -- (C);
\path (A) node[below left] {A} -- (B) node[above] {B} -- (C) node[below right] {C} -- (N) node[above right] {N} -- (P) node[below=5pt] {P} -- (C) node[above=5pt, left=25pt] {$\alpha$} -- (N) node[left=5pt] {$\theta_1$} -- (B) node[below=30pt,left=-2pt] {$\theta_2$} -- (B) node[below=12pt,right=-2pt] {$\theta_3$} -- (C) node[above=20pt, left=25pt] {$\theta_4$};
\end{tikzpicture}
where:
\(\displaystyle \theta_1=90^{\circ},\,\theta_2=20^{\circ},\,\theta_3=40^{\circ},\,\theta_4=30^{\circ}\)
Can you find $\angle\text{NPB}$?
$\angle NPB=50^o$ what next?
Then what must $\angle\text{BPA}$ be?
$30^o$ and?
maxkor said:
$30^o$ and?
We should have:
\(\displaystyle \angle\text{BPA}+50^{\circ}=180^{\circ}\)
Hence:
\(\displaystyle \angle\text{BPA}=130^{\circ}\)
Do you see any other angles you can fill in?
Okay, we now have:
\path (A) node[below left] {A} -- (B) node[above] {B} -- (C) node[below right] {C} -- (N) node[above right] {N} -- (P) node[below=5pt] {P} -- (C) node[above=5pt, left=25pt] {$\alpha$} -- (N) node[left=5pt] {$\theta_1$} -- (B) node[below=30pt,left=-2pt] {$\theta_2$} -- (B) node[below=12pt,right=-2pt] {$\theta_3$} -- (C) node[above=20pt, left=25pt] {$\theta_4$} -- (P) node[above=22pt, right=0pt] {$\theta_5$} -- (P) node[above=5pt, left=0pt] {$\theta_6$};
\end{tikzpicture}
where:
\(\displaystyle \theta_5=50^{\circ},\,\theta_6=130^{\circ}\)
What else can we fill in?
$\angle PAB=30^o,\angle APC=120^o, \angle NCP =120^o$ and?
What I find is:
\(\displaystyle \angle\text{PAB}=30^{\circ},\,\angle\text{NPC}=60^{\circ},\,\angle\text{APC}=120^{\circ}\)
We have two angles left to find...can you identify them?
For example, I don't know how to find $\angle PAC$
Let's let:
\(\displaystyle \angle\text{PAC}=\beta\)
So, we may state:
\(\displaystyle \alpha+\beta+120^{\circ}=180^{\circ}\)
or:
\(\displaystyle \alpha+\beta=60^{\circ}\)
Now, consider the right triangle $\triangle\text{ANC}$. Let:
\(\displaystyle x=\overline{NC}\)
\(\displaystyle y=\overline{AN}\)
\(\displaystyle z=\overline{AC}\)
By Pythagoras, we have:
\(\displaystyle x^2+y^2=z^2\)
Can you express the area of the right triangle in 3 different ways, so that we have 5 equations in 5 unknowns?
Yes but when I use
$S=0.5xy$
$S=0.5xz\sin(60-\alpha)$
$S=0.5zysin(\alpha+30)$
$sin^2(60-\alpha)+sin^2(\alpha+30)=1$ it is identity
maxkor said:
Yes but when I use
$S=0.5xy$
Yes, I keep going in circles with identities...I suppose another approach is needed. :D
Using values as given by Mark's diagram, notice that $P$ is the orthocenter of $\triangle{ABC}$, so $\alpha=90^\circ-\theta_3-\theta_4=20^\circ$.
FAQ: Finding $\angle PCA$ in Triangle ABC with $\angle ANB = 90^\circ$
What is the given information for solving for $\angle PCA$?
The given information for solving for $\angle PCA$ is that it is a triangle ABC with a right angle at point N, and we are trying to find the measure of angle PCA.
How can we use the given information to solve for $\angle PCA$?
We can use the fact that angle ANB is a right angle to create a right triangle ANB. Then, we can use the properties of right triangles and the given information to solve for the measure of angle PCA.
What are the steps for finding $\angle PCA$?
The steps for finding $\angle PCA$ are as follows:
  1. Draw a diagram of triangle ABC with a right angle at point N.
  2. Label the sides and angles of the triangle using the given information.
  3. Use the properties of right triangles to set up an equation involving angle PCA.
  4. Solve the equation to find the measure of angle PCA.
Can we use trigonometric ratios to solve for $\angle PCA$?
Yes, we can use trigonometric ratios such as sine, cosine, and tangent to solve for $\angle PCA$. These ratios relate the sides of a right triangle to its angles and can be used to find missing angles or sides.
Are there any special cases to consider when solving for $\angle PCA$?
Yes, there are a few special cases to consider when solving for $\angle PCA$. If triangle ABC is a right triangle, then $\angle PCA$ will be either 0 or 90 degrees. If triangle ABC is an isosceles right triangle, then $\angle PCA$ will be either 45 or 135 degrees. Additionally, if triangle ABC is an equilateral triangle, then $\angle PCA$ will be 60 degrees.
