Finding Angular Displacement in a Pirouette
A dancer completing 2.2 revolutions in a pirouette has an angular displacement calculated as 2.2 revolutions multiplied by 2π, resulting in 14 radians. The confusion arises from the concept of angular displacement, which is the difference between the final and initial angular positions. Since the dancer returns to the starting point after 2 full revolutions, the effective angular displacement is indeed 0.4 radians for the additional 0.2 revolutions. However, the total angular displacement over the entire motion is still 14 radians, as it accounts for the complete rotation. Understanding the distinction between total rotations and effective displacement is crucial in solving such problems.
Spartan301
Hey, I have a very easy problem.
A dancer completes 2.2 revolutions in a pirouette. What is her angular displacement?
here's my work.
Given:
2.2 revolutions.
Battle Plan:
Find angular position in radians.
Subtract final position with the initial position.
Outcome:
2.2 x 2pi = 4.4 pi radians
=13.823
sig figs: 2
=14 rad
The key says 14 rads is correct, but I'm confused because I thought that you had to subtract the final position from the initial position.
If I did that to find the true angular displacement, wouldn't it be something like 0.4 rads?
Does my math look correct, or is there a concept I'm missing?
Thanks so much.
-Tom
The initial angular displacement is zero.
Certainly. But she passes 0 two times. After that she only rotates for about 0.2 revolutions, right? Wouldn't that be the angular displacement instead?
-Tom
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
