Finding Approximate Location of Particle at Time t=1.05
Kokordilos
This isn't really even a homework question..i've just been reviewing some general math concepts and this one has been driving me nuts..i haven't done math in a while.
At time t = 1, a particle is located at position (1,3). If it moves in a velocity field F(x,y) = <xy-2,y^2 - 10>, find its approximate location at time t = 1.05
n/a
I thought, maybe:
dx/dt = xy - 2 and dy/dt = y^2 - 10
So I can integrate, so x(t) = (1/2)x^2 * y - 2x + C and y(t) = (1/3)y^3 - 10Y + C and solving for the constants is trivial based on the initial conditions, but then I get totally confused. How do I put this in terms of T? And did I even do this right? It doesn't make sense to me that the position should be the function of a position. I must have done my integral wrong.
Can you guys help me out...really stuck.
anyone?
Here's how I would approach it, and if anyone disagrees, I hope they will jump in and correct my reasoning.
You have the velocity field F(x, y) = (xy - 2, y^2 - 10). I agree that the components are dx/dt and dy/dt.
For small values of \Delta t, F(x, y) \Delta t should give the approximate changes in x and y.
IOW, (dx/dt, dy/dt) \Delta t \approx (\Delta x, \Delta y)
or (x, y) + (dx/dt, dy/dt)*dt \approx (x, y) + (\Delta x, \Delta y), where x, y, dx/dt, and dy/dt are evaluated at t = 1.
Because the time increment is relatively small, the changes in x and y probably will be relatively small as well, so you should end up at a point not far from (1, 3).
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
