Finding Area with Double Integrals: What is the Approach for This Homework?
catch22
here is my approach,
I take the whole area, which is π16
then subtract the unshaded region
now to find the unshaded region's area, I use rectangular coordinates.
my bounds are from -2 to 2 for x and the the top and bottom of the larger circle : sqrt (16-x^2) and -sqrt (16-x^2)
but now I don't know if there should be an integrand or assume it is 1 if none is given?
When you integrate for area, the integrand is 1.
Likes catch22
Here's how I like to think of it. If the amount of integrals that you're doing is the same as the exponent on your units would be, then the integrand is 1. For example, if you're calculating an area, your units would be square units (exponent 2), so with a double integral the integrand is one. So if you're calculating a volume, with a triple integral your integrand is 1 but with a double integral it isn't.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
