Finding argument of complex number
The discussion focuses on solving the equation z + 1/z = 1 + 2i for the complex number z. Participants suggest various methods, including solving a quadratic equation and manipulating expressions involving z. Some express concerns about the complexity of their approaches, while others propose a more straightforward method that avoids directly calculating z. Ultimately, the conversation highlights different strategies for tackling the problem, emphasizing the potential for simpler solutions while acknowledging the challenges in finding them. The exchange underscores the collaborative nature of mathematical problem-solving.
songoku
For ##z+\frac 1 z = 1+ 2i##, find ##|z^2 - \frac{1}{z^2}|##
conjugate
modulus of complex number: ##|z|=\sqrt{x^2+y^2}##
Let: ##z=x+iy##
$$z+\frac 1 z =1+2i$$
$$x+iy +\frac{1}{x+iy}=1+2i$$
$$x+iy+\frac{1}{x+iy} . \frac{x-iy}{x-iy}=1+2i$$
$$x+iy+\frac{x-iy}{x^2+y^2}=1+2i$$
$$\frac{x^3+xy^2+x+i(x^2y+y^3-y)}{x^2+y^2}=1+2i$$
So:
$$\frac{x^3+xy^2+x}{x^2+y^2}=1$$
$$x^3+xy^2+x=x^2+y^2$$
and
$$\frac{x^2y+y^3-y}{x^2+y^2}=2$$
$$x^2y+y^3-y=2(x^2+y^2)$$
Combining the two equations: ##x^2y+y^3-y=2(x^3+xy^2+x)##
How to solve that equation? Or maybe there is another approach to this question?
Thanks
songoku said:
Homework Statement:: For ##z+\frac 1 z = 1+ 2i##
Not sure it's the best, but an obvious thing to try is to solve that quadratic
Likes songoku
Yes, I think dealing with ##z## instead of ##x + iy## is best. Also note that ##z^2- \frac{1}{z^2} = (z+\frac{1}{z})(z-\frac{1}{z})## may help. That's how I did it.
It does seem like brute force to me though. I bet someone has a more clever solution.
Likes songoku
Yes, I suspect there's a neat way which avoids finding z.
I tried ##|z^2-z^{-2}|=\frac{|z^2-1|}{|z|}\frac{|z^2+1|}{|z|}=\frac{|z^2-1|}{|z|}|1+2i|##, but it wasn't obvious where to go from there.
Likes songoku
I will try this and brute force it. Thank you very much haruspex and DaveE
There is a relatively simple solution. I show it to you after you make an attempt yourself with these hints:
1) Stay with z, not the rectangular or polar forms.
2) I preferred to say ##Z_o \equiv z+\frac{1}{z} = 1+2i ## but this was mostly to save writing ##1+2i ## repeatedly.
3) Solve the quadratic equation to get roots ##Z_{1,2}## in terms of ##Z_o##.
4) Factor ##z^2-\frac{1}{z^2}## as in my previous post. Simplify this function by substituting ##Z_o## as much as possible.
5) Substitute the quadratic roots ##Z_{1,2}## into the simplified form of ##z^2-\frac{1}{z^2}##.
You will get a relatively simple answer without ever actually putting in the value of ##Z_o## until the end. The algebra should never get really messy.
If you get stuck, describe where/what/how and I'll help.
Likes songoku
I think this solution is fairly easy
## (z+\frac{1}{z})^2 = -3+4i ##
Then ## z^2+2+ \frac{1}{z^2} = -3+4i ##
if you subtract 4 from both sides it is ## (z-\frac{1}{z})^2 = -7 + 4i ##
Now we know what ##(z^2-\frac{1}{z^2})^2## is
and from here it can easily be calculated.
Likes SammyS, PeroK, songoku and 1 other person
Now we know what ##(z^2-\frac{1}{z^2})^2## is...
Do you mean: "now we know what ##(z-\frac{1}{z})^2## is" ?
I tried this and I think I also got the same result using method suggested by @Sunay_
In the end, I need to find ##\sqrt{-7+4i}## and then multiply by ##1+2i## to get ##z^2-\frac{1}{z^2}## and after that finding the modulus.
I also tried brute force and it almost cost me my life
Using @DaveE method:
$$z+\frac 1 z=Z_o$$
$$z^2-Z_o z+1=0$$
$$z=\frac{Z_o \pm \sqrt{Z_o^2-4}}{2}$$
Then
$$z^2-\frac{1}{z^2}=\left(z+\frac 1 z \right)\left(z - \frac 1 z\right)$$
$$=Z_o(2z-Z_o)$$
$$=Z_o(2 . \frac{Z_o \pm \sqrt{Z_o^2-4}}{2} - Z_o)$$
$$=\pm Z_o \sqrt{Z_o^2 - 4}$$
Edit: Wait, I think I understand what @Sunay_ meant by we know ##\left(z^2-\frac{1}{z^2}\right)^2##. I will try and compare
Likes Sunay_ and DaveE
songoku said:
Do you mean: "now we know what ##(z-\frac{1}{z})^2## is" ?I tried this and I think I also got the same result using method suggested by @Sunay_
$$z+\frac 1 z=Z_o$$
$$z^2-Z_o z+1=0$$
Then
$$=Z_o(2z-Z_o)$$
$$=Z_o \sqrt{Z_o^2 - 4}$$
Yes, although you left out the ##\pm## part at the end, because of the square root. Of course it doesn't matter if you only need the magnitude.
Both methods are basically the same. When @Sunay_ "completed the square" that was equivalent to the quadratic formula. I think her method is a little nicer, maybe shorter, but I wouldn't have a good argument why.
Likes PeroK, songoku and Sunay_
Yes, I just realized it
I also think @Sunay_ method is shorter but not everytime I can think of that method by myself so I am okay with longer method (as long as it is easier for me to find it) although it takes more time during the test
Thank you very much for all the help and explanation haruspex, DaveE and Sunay_
Here's another variation:
$$z + \frac 1 z = w \ \Rightarrow \ 2z = w \pm \sqrt{w^2 - 4} \ \ (quadratic)$$
$$2z = (z + \frac 1 z) + (z - \frac 1 z) = w + (z - \frac 1 z)$$
$$\therefore \ z - \frac 1 z = \pm \sqrt{w^2 - 4}$$
$$z^2 - \frac 1 {z^2} = (z + \frac 1 z)(z - \frac 1 z) = \pm w\sqrt{w^2 - 4}$$
Likes songoku and DaveE
