Finding center of mass of a picture
To find the center of mass (CoM) of a uniform sheet of steel, first determine the x and y coordinates separately by analyzing the mass distribution. The CoM is the point where mass is symmetrically arranged, meaning equal mass on either side of the chosen axis. For the x direction, identify the value where mass is evenly distributed, and do the same for the y direction. The final coordinates for the center of mass in this case are (7, 8). Understanding these principles is crucial for solving related problems effectively.
runawayshoes
hey everyone, I am stumped as to finding the x and y coords of the center of mass of this picture. it is supposed to be a uniform sheet of steel in increments of 6. please help, i have an exam tomorrow.
What exactly is the centre of mass?
Once you have the answer, you can "decompose" it into two components, x and y. So you'd basilcally find the centre line along x, then along y, and your centre point would be the intersection of the two.
i'm still stumped heh
Find the CoM in each direction seperately. Meaning stack all the blocks so that you only have one direction to deal with at a time. For example, imagine a figure with 3m on the left column, 2m in the middle column, and 1m on the right column (where m is the mass of one block). then find the center of mass of those 3 blocks, this corresponds to the CoM in the x direction. Do something similar for the y direction.
The centre of mass is a point around which all the mass is symmetrically arranged.
Take the x direction for example. For what value of x would the mass be symmetrically distributed, i.e. you have the same mass to the right and to the left of your x value?
Note that if you balance your plate on a knife edge placed at that x, the plate would be in equilibrium.
i got it, thanks. answer is (7,8) btw
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
