Finding Conditonal Probability
  • Thread starter Thread starter mckallin
    Probability
mckallin
There are w white balls and b black balls in a bowl. Randomly select a ball from the bowl and then return it to the bowl along with n additional balls of the same color. Another single ball is randomly selected from the bowl(now containing w+b+n balls) and it is black. Show that the conditional probability that the first ball selected was white is w/(w+b+n)
Relevant equations
The conditional probability of an event A, given that an event B has occurred, is equal to:
P(AlB)=P(AnB)/P(B)
The attempt at a solution
This is my last question of my assignment and I can't figure out even how to get the first step. The condition we know here is an event happened afterward, so I am even confused if I should use the equation above. I try to list the sample points which are A(1st-w, 2nd-w), B(1st-w, 2nd-b), C(1st-b, 2nd-b), D(1st-b, 2nd-w), and the possible sample points should be B or D. Then I try the conditional probability for B:
Sample point B :
Being the first selecting:
P(w)=w/(w+b) P(b)=b/(w+b)
By sample point B, it supports that the first selected ball is white, second is black, so using the equation:
P(blw)=P(bnw)/P(w)=P(bnw)/[w/(w+b)]=b/(w+n+b)
so, P(bnw)=[w/(w+b)]*[b/(w+n+b)]
Here it already looks strange because B is just one of the sample points, but I still continue:
P(wlb)=P(wnb)/P(b)={[w/(w+b)]*[b/(w+n+b)]}/[b/(w+b)]=w/(w+b+n)
I got the answer, but I have no feeling for that. It was that I was just putting something into an equation with no reason. But when I tried other ways, it even went worse. If anyone can give me some ideas just like how I should start to prove and that will be great.
I don't understand what the question is asking: "Show that the conditional probability that the first ball selected was white is w/(w+b+n)" This doesn't make any sense. The probability that the first ball selected is white is clearly w/(w+b) unless i am horribly, horribly mistaken. Reread the question.
EDIT: Oh never mind, I missed the part where the second ball selected was black.
After studying this problem further, I decided I don't know enough to help you out, sorry. Hopefully someone else can explain.
I think it means that at first the color of the ball is unknown, and given the condition that the second selected ball is black; thus, under this condition what the probability of the the first ball selected was white is.
That is what I got. I agree with your meaning though, but anyway that is what the question is asking, driving me cruzy.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
