Finding displacement from position time graph
  • Thread starter Thread starter syllll_213
    displayengineering
Displacement is calculated as the change in position over a time interval, defined as the final position minus the initial position. In this case, the final position is -15 meters and the initial position is +25 meters, resulting in a displacement of -40 meters. There is no assumption about direction needed for this calculation; it is strictly based on the positions provided. The answer key may contain an error if it suggests a different value. The correct displacement is confirmed to be -40 meters, including the necessary units.
syllll_213
For e I am asked to find the displacement of the object, and I could find the total distance travelled (25m + 15m )= 40m and I assumed the direction is the same therefore it will be the displacement for the object. However the answer is -35m and I am unsure why.
distance travelled = area under velocity time graph
Its displacement is its change in position between over the time interval. Final position ( relative to coordinate frame) minus its initial position relative to coordinate frame. What do you get for that?
-40?
syllll_213 said:
-40?
Yeah, that’s what I get too (meters-don’t forget units). So I suspect an error with the answer key.
syllll_213 said:
. . . I assumed the direction is the same . . .
No such assumption is warranted. Displacement is (final position) - (initial position).
Here, the final position is -15 m and the initial position is +25 m.
So the displacement is (-15 m)-(+25 m) = -40 m.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
