Finding Displacement, Velocity, and Acceleration in a Viscously Damped System
A viscously damped system with a weight of 250 N, spring stiffness of 8 kN/m, and a damping coefficient of 0.08 kN-sec/m is analyzed to find displacement, velocity, and acceleration after being disturbed from equilibrium. The initial conditions include a velocity of 0.25 m/sec and no initial displacement. Participants emphasize the need to use the correct equations for damped motion, as the standard equations for constant acceleration do not apply. There is confusion among students regarding the application of the physics concepts, as they have limited prior exposure to the topic. Understanding the "damped harmonic oscillator" is crucial for solving the problem effectively.
andrewport87
A viscously damped system has a total weight of 250 N, a spring stiffness k = 8 kN/m,
and a damping coefficient c = 0.08 kN-sec/m. Determine the displacement, velocity,
and acceleration of the mass as a function of time if it is disturbed from its equilibrium
position with an initial velocity of 0.25 m/sec with no initial displacement. Calculate
the displacement, velocity and acceleration of the mass at t = 1.75 sec.
N?A
I don't know where to start with this, i tried, x = ½( v + v0 )t
Where:
x = displacement
v = velocity
v0 = initial velocity
but the question doesn't give all the varibales needed, think I'm going about it the wrong way
hi man, welcome to physicsforums!
You need to use an equation which takes into account the physics of the situation. Do you know what equation to use if it was just a mass on a spring? And have you learned about how the equation should change when the motion of the mass is damped? They do give enough information, as long as you know what the equation is.
Where:
x = displacement
v = velocity
but the question doesn't give all the variables needed, think I'm going about it the wrong way
That equation only works for situations involving constant acceleration.
As BruceW noted, you first need to identify the proper physics. The phrase "viscously damped system" is a clue. The fact that there's a spring, a mass, and a damping coefficient is another.
To be honest, we got a crash course on the subject in 2 hours, then gave an assessment on it so we really haven't learned any of it and reading through the notes none of it makes sense. I'm a 4th year under graduate student and this is the first time I've ever done anything like this, its completely new, i don't even know the basics if I'm being completely honest, this has basically just been through at us and told to work through it.
only equation i can find for dampening force is:
Fd = cx
where x is the velocity and c is the coefficent and Fd is the dampening force, but again missing one of the variables, i think I'm missing something completely out
Try looking up "damped harmonic oscillator." This is typically covered in freshman physics.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
