Finding electric field via a given potential
The discussion revolves around calculating the electric field from a non-uniform charge density on a plastic rod and determining the correct potential and field values at a specific point on the x-axis. Participants have derived various electric field values, including -3.47 x 10^3 N/C and -1.45 x 10^4 N/C, but there is confusion regarding the sign and direction of the field due to the rod's placement. Clarifications reveal that the rod's position is crucial for accurate calculations, as it affects the interpretation of the electric field's direction. The consensus is that the electric field should point to the left, indicating it is negative, but discrepancies in calculations persist among participants. The complexity of the problem and differing interpretations highlight the challenges in solving such physics problems accurately.
DannyPhysika
The plastic rod of the length L=1 m has a non-uniform charge density λ=cx where positive constant c =2x10^-6 [some unit]. What unit c has to have? Find the electric potential at the point on the x-axis 1 m to the left from the left end of the rod. Find the electric field at that point via potential. What is the direction of the field
E = -dV/dx
The first two parts I've solved. For the electric field:
I've gotten:-3.47 x 10^3 N/C
or
-1.45 x 10^4 N/C
But I'm not sure which is good. Thanks for any information :)
Although I'm tempted to say that E will be equal to V because E is simply V/m and the question asks for the electric field 1m away, however, since the charge is non-uniform I assume you have to take the partial derivative of your derived expression which should be:
Ke*c([L-d*ln(1+(L/d))]
If I differentiate that with respect to d, I get that E = -(-3472) N/C which means that it is positive. But shouldn't it be negative?
Show how you got your answers so we can help you.
I've done all my work on paper and I ended up with E(x) = -kc[ln(L-x) + x/(L-x) -1 -ln|x|] where x = -d where d is 1m. It's been a couple days but I plugged in my numbers and got 1.45 x 10^4 N/C. But this is a positive answer, shouldn't the electric field be to the left/negative?
Isn't the positively charged end of the rod nearest to x = 1m? Then E field is to the right.
I got somewhat different answers.
4.225×103 V/m
I've just spent time with another student with this problem and we're really lost because we've got 4 different answers from different sources and not one of them are the same. We've gotten 8.99 x 10^3 N/C, -3.47 x 10^3, -1.45 x 10^4 N/C, and 4.225 x 10^4 N/C from the above poster. Can anyone else say that they've gotten one of the above answers? Thank you for any confirmation.
Well, I see that I've mis-read the problem. I had the rod centered at the origin, and found the E field at x = 1m .
I don't see any information about where the rod is located relative to the origin. I do see (now) that the question asks for the E field at a location 1 meter to the left of the end of the rod. Since linear charge density, λ, depends upon x, the rod's location relative to the origin is very important.
Yes it is a rather badly worded problem...
But yes, from my discussion with other students, we placed the rod's extreme left end at the origin. I wish I could show my work but I have it on paper and this is the last thing I have not done for this 5 problem assignment. I will have to pick one of the answers before class starts, I just wish I had more of a unanimous consensus on its value.
Well with that placement of the rod, the e field at x = -1 meter is definitely to the left (negative).
I'll look again, quickly.
Added in Edit:
What I have this time:
-1.738×103V/m
The total charge on the rod is c/2 Coulombs = 1.0×10-6 C, with 3/4 of that being to the right of x = 1/2.
The electric field at x = -1 m due to a point charge at x = 1/2 m, is E = -4×103 V/m.
That may help more than my rushed integration & differentiation & plugging stuff in.
If V = kc (integral) (x)dx/(d+x)
then shouldn't E = -dV/dx where dV/dx just equals (d/dx)(kc (integral) (x)dx/(d+x)) which equals (kc(x))/(d+x)
so E = -(kc)(1/2) = -8.99 x 10^3 N/C ?
I different approach tells me I like the -3.47 ... answer .
Not no, but ... No Way.
For one thing in the integral x refers to a location along the rod, while in dV/dx, the x refers to the position at which you are finding the E field.
Also how did you let the x from the numerator jump out of the integral?
Ok I am also getting 3472.8 but I'm getting positive because it's:
E = -kc((x/x+L) - ln|x+L| + 1 + ln|x|) which gives -kc(-.19) which is 3472.8?
The field is definitely to the left if the rod lays from 0 to 1 on the x-axis.
The potential at r distance from a charge element dq is equal to kdq/r. If the rod of length L is placed with its left end in the origin, and the charge element is at distance \xi from the origin, r=x-\xi if x>L and r=\xi-x if x<0. See picture.
For negative x values then, the potential is
U(x)=k\lambda \int_0^L{\frac{\xi}{\xi-x}d\xi}=k\lambda (L+x ln(1-\frac{L}{x})).
The electric field is shown in the second picture.
ehild
