Chemistry Finding equilibrium expression for an equilibrium equation
The discussion centers on the formulation of an equilibrium constant for a reaction involving only liquids. It clarifies that while solids and pure liquids are excluded from equilibrium expressions, the reactants in this case are dissolved in a solvent, making them effectively aqueous. Participants emphasize the importance of converting masses to moles and using molarities in calculations. The confusion arises from the typical exclusion of certain phases in equilibrium expressions, but it is noted that an expression can always be derived. Understanding the properties of the substances involved is crucial for correctly setting up the equilibrium equation.
haha0p1
Write the equilibrium expression for this reaction
Kc=(product A)×(product B)
(Reactant A)×(Reactant B)
In the d(i) part, we are asked to write an equilibrium constant. It was mentioned in the chapter that solids and liquids will not be added in the equation. So, I think that there is not going to be any Expression for this reaction as all the reactants and products are liquids. Is my answer right?
Solids and immiscible liquids.
I suggest you use square brackets in your above expressions to remind yourself that you are dealing with molarities.
You need to convert the masses of your reactants into moles using their respective molar masses. You can then find the initial concentrations from the moles and the given volume. The reactions shows the reactants as liquids but they are being dissolved in a solvent which then makes them aqueous. You need the values for part (a) in order to complete the entire problem.
There's always an expression. The reason we don't include materials with certain properties is because their activities evaluate to 1, i.e. something multiplied by 1 is itself, so it's not written out. The confusion likely arises from the fact that we usually only include (g) and (aq) samples in these equations, since a lot of problems are concerned with dissolved gases, salts or acid/bases. However, this problem deals with a mixture of liquids rather than what we would usually consider a solution (i.e. something solid or gaseous dissolved).
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
