Finding Equilibrium of Forces: A Shortcut Method
The discussion revolves around solving a physics problem involving forces and geometry related to a hemisphere and a rod. Participants debate the angles formed by the forces and the geometry of the setup, with emphasis on understanding the relationships between the angles and the forces acting on the system. Key points include the identification of normal forces, the need for accurate diagrams, and the implications of angles in relation to equilibrium conditions. The conversation highlights the importance of visualizing the problem correctly to derive the necessary equations for equilibrium. Ultimately, the group aims to clarify the relationships between the forces and angles to solve the problem effectively.
thevinciz
49
The questions are in the comment box. Sorry!
https://www.img.in.th/image/V9K8Rg
1. I think α = 90 because BD is normal force.
and I don't know anymore
PS. sorry for bad english
Looks like we tried to fix the images at the same time.
Normal to what? What does that tell you about the geometry?
I think it is a normal force (from hemisphere) acting on the bar, so ABD which is angle of normal force should be 90 degree.
Can you answer (2) now? Hint: Draw a good diagram, to scale if you can.
If I call a point (located at middle of BC) O, I think OA and OB are radius. Because OA and OB have same length so BAD = ABC. Is this correct?
Right, but exactly what is your reasoning?
I'm sorry I don't understand what you mean
You are right that BAD=ABC, but I do not see how you deduced that. Might be something simple I am missing.
OA and OB having the same length tells you that BAO and ABO=ABC are the same. There is a step missing.
AD and BD are normal force which are perpendicular to a tangent line of hemisphere. Therefore AO and BO are radius of the hemisphere.
I just explain it above this comment, could you check it please?
sorry for bad English
Could you guys help me the question 3-5 please
Ah yes, I see. Except, BD is not perpendicular to the tangent. It is perpendicular to the rod.
For 3, try to draw the diagram specific to that case.
Where is A now?
Thanks , I made a mistake
The key to this problem is this. Consider the point of intersection of segments AD and CE. What's special about it? Then either draw to-scale diagrams specific to each case as @haruspex suggested or derive a general expression for the ratio of the length to diameter in terms of angle and see what it is for each angle.
I believe thevinciz did that in determining that OA and OB are radii.
Ah, I read your post as intersection of AD and CB. You really did mean CE?
Indeed, but what about OD?
Yes OD is interesting, but please see my edit to post #19.
I read the edit. I meant the intersection of AD and CB. Note that the normal force at A is centripetal ...
For the question3, I have found that if θ=45° (β=45° too because β=θ) this configuration is impossible.
Because we will have AOB = 90° and the nearby angle 90° (the angle of above triangle that is located on AD) but the above triangle has 90° angle already, so the other angle will be 0°. Therefore it is impossible.
Is this correct. Sorry for bad English again. I'm trying my best
I was hoping you meant that. Thanks for confirming.
Yes.
You've lost me. Can you explain using the names of the points? Name some more points if necessary.
haruspex said:
Yes.
I'm trying to insert a picture, sorry.
Can you just say where it puts D in relation to the rod?
I don't know
thevinciz said:
I don't know
We have already established that BD is perpendicular to the rod. This means that triangle ABD is a right triangle with hypotenuse AD. How is AD related to the diameter of the circle? You may not be able to see what's going on unless you draw a good diagram as I have repeatedly suggested. The one provided to you appears to be deliberately misshapen perhaps so that nothing is given away. Try redrawing it, making the circle as round as possible and the perpendiculars as "perpendicular" as possible.
  • #31
Oh I see, thanks you very much, I'll try draw it.
  • #32
I have drawn it, AD is a diameter?
  • #33
Yes! Based on that knowledge, what kind of triangle is BOD? What are its 3 angles in relation to ?
  • #34
kuruman said:
Yes! Based on that knowledge, what kind of triangle is BOD? What are its 3 angles in relation to ##\theta##?
But I still don't know how to find AE to answer question5, could you give me more hint?
  • #35
thevinciz said:
Those 3 angles are 60°
No, it is not necessarily equilateral. BD need not equal the radius.
It would help to find the answer to my question in post #27.
If exactly three forces act on a body in equilibrium, what can you say about the lines of action of the three forces? Consider moments.
  • #36
Thanks I really made a mistake, I have deleted already.
  • #37
I will think with your method, but could you check my method please.
OD=OB (because they are radii) so ODB=OBD=45°. Then we will have θ=45°. Therefore question 3 and 4 are impossible.
  • #38
thevinciz said:
so ODB=OBD=45°
Why?
Compare DAB with DOB. There is a theorem you should know.
  • #39
It is correct that ODB = OBD which makes triangle DOB isosceles; @haruspex questioned that the angles are 45o, which is not necessarily true. Knowing one of these angles means knowing all of them because their sum must be equal to 180o. If you do not know or do not remember the theorem that @haruspex mentioned, do this. Draw a line perpendicular to diameter CB at point B. What is the angle formed by this perpendicular and the normal force at B in relation to angle ABC? Remember your answers to parts (1) and (2). What is this angle's relation to ?
  • #40
haruspex said:
Why?
Do you mean DOB = 2(DAB)?
  • #41
kuruman said:
It is correct that ODB = OBD which makes triangle DOB isosceles; @haruspex questioned that the angles are 45o, which is not necessarily true. Knowing one of these angles means knowing all of them because their sum must be equal to 180o. If you do not know or do not remember the theorem that @haruspex mentioned, do this. Draw a line perpendicular to diameter CB at point B. What is the angle formed by this perpendicular and the normal force at B in relation to angle ABC? Remember your answers to parts (1) and (2). What is this angle's relation to ##\theta##?
Is it θ?
  • #42
thevinciz said:
Is it θ?
Are you asking me or are you telling me? What do you think?
  • #43
Actually it was a answer to your question.
  • #44
For question4 (θ = 75/2), I still don’t see how impossible it is.
  • #45
Great! Yes, it is . Now you should be able to label all relevant angles as , , or . Having done this, 1. Write all forces in component form.
2. Choose a convenient origin (I chose point A), write the position vectors for the force at B and the force at G.
3. Find the torque generated by each force and set the sum of torques equal to zero. This should give you a relation between the magnitude of the force at B, the weight and the ratio L/D.
4. Use the fact that the sum of all the horizontal and vertical components of forces are separately equal to zero to find an equation relating L/D to θ. You also do this by noting that since the forces add to zero, they must form a triangle which is not necessarily right, isosceles or equilateral. If you label the internal angles correctly, you should be able to use the law of sines to get the relation between L/D and θ in fewer steps.
5. Once you have the desired expression, substitute the values of 3-5 and see whether you get a reasonable value for L/D.
  • #46
kuruman said:
Great! Yes, it is ##\theta##. Now you should be able to label all relevant angles as ##\theta##, ##2\theta##, ##90^o-\theta## or ##90^o-2\theta##. Having done this, 1. Write all forces in component form.
Going out into details of all the forces can be avoided using my hint in post #35.
  • #47
Yes. I thought OP may be more comfortable with the "brute force" method. Nevertheless, I did mention a shortcut under item 4, post #45 that works well.
