Finding Final Temperature of Ideal Gas from P vs V Graph
To find the final temperature of a monatomic ideal gas from a P vs V graph, one must utilize the ideal gas law, which relates pressure (P), volume (V), and temperature (T). The initial temperature at point A can be used alongside the changes in pressure and volume to calculate the final temperature. The area under the curve or the specific path taken on the graph may also provide insights into the work done on or by the gas, impacting its thermal state. Understanding the relationships between these variables is crucial for accurate calculations. Ultimately, applying the ideal gas law allows for determining the final temperature based on the provided graph data.
cluelessstar
Given a graph of P vs V of a monatomic ideal gas, how can we find the final temperature when the inital temperature is given ?
Thx~
What do you know about the relationship between pressure, volume and temperature?
http://img107.imageshack.us/img107/3283/untitledlt5.jpg
This is what the diagram looks like with given temperature at A.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
