Finding final velocity given 2 charges
The discussion revolves around calculating the final velocity of a charged sphere (q2) as it approaches another charged sphere (q1) and determining how close they get to each other. The key approach involves using the conservation of mechanical energy, where the sum of kinetic energy (KE) and potential energy (PE) remains constant. The user initially struggles with the equations and concepts, particularly in applying the potential energy formula and understanding the relationship between KE and PE at different distances. They correctly identify that at the point of closest approach, the kinetic energy of q2 will be zero. The final goal is to find the speed of q2 at a distance of 0.410 m and the minimum distance it reaches to q1.
Josh930
A small metal sphere, carrying a net charge of q_1 = -2.70 \mu C, is held in a stationary position by insulating supports. A second small metal sphere, with a net charge of q_2 = -7.60 \mu C and mass 1.50 g, is projected toward q_{1}. When the two spheres are 0.800 \rm m apart, q_{2} is moving toward q_{1} with speed 22.0 \rm m/s . Assume that the two spheres can be treated as point charges.
What is the speed of q2 when the spheres are 0.410 m apart?
How close does q2 get to q1?
F=k(Q1Q2)/r^2
U=k(Q1Q2)/r
I don't really know how to do this problem but i started it in this process-
The potential energy is the work done in moving the charge through the electric field. That Potential energy is donated U. So i know that the work done in the system will equal a force x distance. F = ma. ( Work= Fd). so the U = ma x distance. Then using this i could find the acceleration and the velocity... problem is i have not time intervals. so I am lost. please help
What is required in the problem?
You don't say what the question is, but it looks like you need to use conservation of mechanical energy, time is not an issue here. KE + PE at one point is equal to KE + PE at another.
so i need to find the electrical potential energy. Then this is equal to the KE= 1/2mv^2;
so K(Q1Q2)/r=1/2mv^2 and solve for v at r .410m for the first question
then how do i find how close they get to each other. Using the same equations and solving for r where ke=u? if so, how do i find v^2 for the KE?
The kinetic energy of the charge q2 is zero at the point of closest approach since it is instantaneously at rest there.
well i worked out part 1 of the problem and got 24.5m/s which is wrong. When finding the potential energy at the point .410, which lies between the 2 charges, do i use .410 for the distance r in the equation;
U=(8.85e9)*(-2.6e-6 * -7.6e-6)/r = 1/2mv^2 ?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
