Finding height dropped from Force vs. Time graph
The discussion revolves around calculating the height from which a pumpkin was dropped based on data from a force vs. time graph. The key equations used include the conservation of energy and the relationship between impulse and momentum. The area under the force vs. time graph represents impulse, which was estimated using a Riemann Sum, yielding a value of approximately 49.72 Nm. This impulse was then used to determine the final velocity of the pumpkin, leading to a calculated height of about 17.29 meters. The participants express uncertainty about the corresponding floor in the skyscraper but confirm the calculations are reasonable.
drierplease
A pumpkin was dropped from a balcony of a skyscraper. The pumpkin happened to land on a sidewalk force sensor and the below data was collected. The pumpkin weighs 2.7kg.
a) From what height was the pumpkin dropped?
b) From what floor of the skyscraper was the pumpkin probably dropped?
Potential Before = Kinetic After: mgh = (1/2)mv^2
Solving for v gives: v = sqrt(2gh)
a = F/m
Vf = a*t+Vi
Sf = .5*at^2+Vi*t+ Si
First I used mgh = .5mv^2 and solved for v.
This gave me v = sqrt(2gh)
I figure that finding the area under the curve of the graph gives the total force on the pumpkin as it is hitting the ground. I haven't done this yet, but I am not too worried about getting an exact answer for this part. I more want to make sure I know how to solve the rest of the problem.
I tried using kinematic equations to solve for height, but I ended up with h being 0, so I think I am not using the right concept and/or equation here.
We are currently studying conservation of momentum, but I don't see how that is helpful here for determining the height the object was initially dropped from.
Hopefully I am missing something obvious?
Hello. Welcome to PF!
The area under the graph does not give you the "total force". It gives you something called "impulse". Review your notes or textbook for information about impulse and how it is related to momentum.
Likes drierplease
Right, I was mistaken. I think I've got it now.
The impulse is equal to the change in momentum over that time period.
Change in momentum = area under the curve = impulse = J
So, using that I solved change in momentum:
2.7(v) - 2.7(0)
2.7v = J
v = J/2.7
I estimated J by using Reimann Sum, got 49.72.
Then I just used conservation of energy, mgh = .5*m*v^2 and got 17.29 meters for h.
Hopefully this is right, I think I didn't quite understand impulse.
I got J = 49.65 Nm and h = 17.24 m.
I'm not sure what floor that was from, but when thinking "skyscraper", it was not very high.
Once again, a problem with more drama and suspense needed. :)
Likes drierplease
Thanks, I'm glad I was close!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
