Finding how high a winch can lift a mass before the battery discharges
The discussion focuses on calculating how high a winch can lift a 50 kg mass before the battery discharges, given a D cell battery with an EMF of 1.5 V and a life of about 10 A/hr. The total power of the system is derived from the formula Total Power = VI - V^2/Rl, where Rl is the load resistance. Participants express confusion about converting power into work without a time variable, emphasizing the need to understand the relationship between power, energy, and time. The efficiency of the winch is noted to be 50%, which accounts for resistance in the calculations. The conversation concludes with inquiries about energy loss due to the winch and how to properly apply the formulas for energy and power.
georgedaisuki
Finding how high a "winch" can lift a mass before the battery discharges
The EMF of the D cell battery is 1.5 V and the life is about 10 A/hr. 50% of the energy int he winch does actual work and the lifting mass is 50 kg. The winch has a load resistance variable of Rl.
Total Power=VI-V^2/Rl
(1.5*10)-10^2/Rl Total power of the system since the question states that the winch's resistance is much greater than the battery's internal resistance. (Thus ignore battery's resistance.)
After finding the total power of the system, I thought that convert the power into work and using mgh to find the max height of winch would work. But at this point, I do not understand how to convert power into work if I do not know the time. Am I to find the height in terms of hours? I've read the book and searched around the internet but the conversion between power and energy is confusing.
Thank You
You are trying to fin the total ENERGY of the system.
power = V * I and energy = power * time = V * I * t
The capacity of the battery if 10 AHour (I*t) - you have written it down wrong.
O I see. That should help me quite a bit. Thank You
also, P is VI but don't I need to take into account the resistance of the winch it's self? Or does the 50% efficiency take into account of the resistance?
Yes the 50% efficency includes everything - the question is much simpler than you are imagining
so in the next problem, we have to assume that the 50% doesn't apply. I now have to find the Rl which would maximize the energy. ..
This is where I would apply the total energy-energy due to winch correct?
My question here is that how do I find energy loss due to the winch? Can i use E=I^2Rt? But I'm confused since I is squared. can I assume that 10 A*hour is just I also? so that energy is 10^2*Rl*t and power is 10^2Rl?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
